Ordered 48 H cams
Old Jan 4, 2019 | 04:34 PM
23Seven's Avatar
23Seven
Originally Posted by paul1970
feel a good power increase ? off the line or just midrange ?
More power throughout the entire RPM range. They are great in the middle but make no mistake these are great cams and come on early and hold up nicely to 6200 if you push it that far.
We’re comparing 48’s that are designed to get the most out of your 96” to OEM Cams that are set to make the EPA happy. So yes they do outperform stock cams from 1000 to 6200 rpm’s.
You’ll also like the idle better, not bad for a mild Cam on an EFI bike. I cheat and set the idle to 950 RPM’s “blap blap blap”
Old Jan 4, 2019 | 04:47 PM
Rodzilla71's Avatar
Rodzilla71
Love these cams in my Ultra. Woke the 96 up big time.
Old Jan 5, 2019 | 09:16 AM
GEORGEW's Avatar
GEORGEW
gonna have fuel moto send a base map to load in my power commander to start and hopefully have it dyno'ed this spring
Who is going to Dyno your bike?
Old Jan 5, 2019 | 09:37 AM
sanman4ever's Avatar
sanman4ever
been thinking of a cam upgrade for a long time finally ordered the andrews 48 cam, adjustable push rods, and lifters from fuel moto, someone tell me i made the right choice LOL
Are you running a 2/1 exhaust?
Old Jan 5, 2019 | 11:11 AM
paul1970's Avatar
paul1970
yes a vance and hines pro pipe
Old Jan 5, 2019 | 11:13 AM
paul1970's Avatar
paul1970
unsure at this point i have a few places in the area but i wanna research who's best
Old Jan 5, 2019 | 11:27 AM
sanman4ever
Your bike is going to be transformed with both performance and sound. You will definitely notice a big difference.
You might be surprised how well the tune you get from FM works.
Old Jan 5, 2019 | 11:36 AM
sanman4ever
Who's doing the install?
Old Jan 5, 2019 | 01:10 PM
Rodzilla71's Avatar
Rodzilla71
Hopefully himself, and save a bunch of money, even after buying a cam bearing tool. Easy job, and if you do it check your cam chain tensioners for wear. Also need to borrow bolt cutters to take out stock pushrods, unless you plan to have rocker boxes off for something else, like adding rockouts, if you have loud ticking top end. Anyway, food for thought. You'll enjoy those cams big time no matter how they get there.
Old Jan 5, 2019 | 02:40 PM
GEORGEW's Avatar
GEORGEW
Give this guy a look ,, https://www.shefferperformancehd.com/
