Abs???
Old Jan 5, 2019 | 08:32 PM
frank zinna's Avatar
frank zinna
Stage II
Default Abs???
My 2013 Road Glide Ultra is have brake issues.
I keep reading some forum posts on abs problems.
Does anyone know how to bypass abs system??
And please spare me the liability speech.
Old Jan 5, 2019 | 08:37 PM
IdahoHacker's Avatar
IdahoHacker
Welcome to HDF!
And, per your request, I'll spare you the preaching.
Old Jan 5, 2019 | 08:38 PM
shorelasHD's Avatar
shorelasHD
Yes, take it back to the dealer to get it done correctly, or at least make them liable if there's a problem and anyone gets hurt. A word to the wise...
Old Jan 5, 2019 | 08:45 PM
frank zinna
Stage II
Thank you hacker.
Old Jan 5, 2019 | 09:20 PM
Budda109's Avatar
Budda109
What kind of issues? It would cost a lot to bypass and make it function correctly. Do you try to bleed them yourself? Does the light keep blinking? Could you be more specific? Also welcome
Old Jan 5, 2019 | 09:55 PM
SkyMaster1's Avatar
SkyMaster1
OMG... no ABS are you F****** crazy? the world will burst into cosmic dust if you bypass your ABS
buy a set of factory non-ABS brake lines, hook em up and bleed, good to go
Old Jan 5, 2019 | 09:59 PM
BB59's Avatar
BB59
Installing the Non-ABS brake line assemblies from the Front and Rear master cylinders to the brake calipers would have the brakes working fine. The Master cylinders and calipers are the same. I'm not sure what would have to be disconnected to keep the ABS system from flashing lights and throwing codes. It might be as simple as unplugging it. Both brake line assemblies can be had for around $200.00 online.
Old Jan 5, 2019 | 10:10 PM
SkyMaster1's Avatar
SkyMaster1
I think you might need to retain the ABS circuit board to keep from throwing codes, and if memory serves the speedo is fed from the ABS tone ring signals
Old Jan 6, 2019 | 09:04 AM
doghead's Avatar
doghead
$200 to delete an $800 option...
Old Jan 6, 2019 | 09:21 AM
Durango Dave's Avatar
Durango Dave
Another "I can stop better without ABS" thread?
What is your problem with ABS? Fix the problem.
There is an issue with brakes failing if you don't change the brake fluid on a regular basis.
