Lights not working
Old Jan 22, 2019 | 10:23 AM
hailo's Avatar
hailo
Stage III
Default Lights not working
Hi Everyone,
I added the Custom Auxiliary Light Kit as well as a new LED headlight. this is on a 2018 street glide
Unfortunately I must have messed up some where.
Out all the new lights ( 5 total: headlight, fog lights, Blinker/running lights...all LED) I have a low beam and one fog light.
No blinkers/running lights and when I go to turn on the high beam nothing happens. The high beam indicator will only stay on when the button is pressed, the minute you take your hand off nothing.
put in LED's on the back as well and those work.
could I have pinched a wire somewhere?
not sure where to go from here...was going to put the blinkers in the back to test and make sure they work also going to move the other fog light to the side that works and see if it works there.
any other suggestions?
thank you in advance,
Anthony
Old Jan 22, 2019 | 11:27 AM
Fireball Jack's Avatar
Fireball Jack
Put all the stock stuff back in. replace one at a time and test. Where did you get the LEDs from?
Old Jan 22, 2019 | 11:54 AM
btsom's Avatar
btsom
LEDs are sensitive to polarity. If they were not made with Harley in mind, your bike may have the negative wire connected to where your LED NEEDS the positive wire to go. Check with a volt meter or conventional bulb to see if the inoperative LEDs actually have power, but the polarity is wrong. Conventional bulbs don't care which wire is positive.
Old Jan 22, 2019 | 12:55 PM
hailo's Avatar
hailo
Stage III
thank you guys for the replies.
The turn signals/running lights are Custom Dynamics ProBEAM: https://www.customdynamics.com/probe...z-1157?cat=820
the Head light/ Fog light is from Amazon :
https://www.amazon.com/Headlight-Matching-Passing-Motorcycles-Mounting/dp/B01B3778TO/ref=sr_1_4?ie=UTF8&qid=1548182784&sr=8-4&keywords=harley+led+headlight https://www.amazon.com/Headlight-Matching-Passing-Motorcycles-Mounting/dp/B01B3778TO/ref=sr_1_4?ie=UTF8&qid=1548182784&sr=8-4&keywords=harley+led+headlight
for the head light I did also buy the 2 into 1 wire adapter as well.
Old Jan 22, 2019 | 01:37 PM
Custom Dynamics's Avatar
Custom Dynamics
Former Sponsor
the Head light/ Fog light is from Amazon : https://www.amazon.com/Headlight-Mat...+led+headlight
hailo, I would also check your Amazon lights on an independent power supply, just to isolate them from the bike and make sure there's no issues with the product. With regards to the ProBEAM signals, please feel free to give us a call and we would be happy to help you troubleshoot. We'll be here today until 5:30 PM EST -- 800-382-1388.
Old Jan 22, 2019 | 08:27 PM
hailo's Avatar
hailo
Stage III
Ok figured out part of the problem. I put the pins in my plug upside down for the auxiliary lights. Turning them around allowed them to push them in all the way. Now they work.
now on to the head light
copter827
May 16, 2018 06:52 AM
sroc3
May 28, 2015 07:48 AM
Stephen Chapman
May 23, 2015 06:06 PM
decencyxdefied
Feb 19, 2015 12:47 PM
spinoleo
Jan 1, 2013 09:35 AM
