Cold starting issue
Old Jan 26, 2019 | 02:37 PM
Joey Mccolloch's Avatar
Joey Mccolloch
6th Gear
Originally Posted by btsom
Thought this sounded familiar, found your original 5 pages back. Ever find an IAC and clean it or replace it, if your machine has one?
my bike does have the iac are you talking about cleaning the sensor? or the actual motor? where is the sensor?
Old Jan 26, 2019 | 02:54 PM
Jackie Paper's Avatar
Jackie Paper
You are correct but it is mechanical kicking mechanical linkage. Do the YouTube to on it and what it should be doing.
Old Jan 26, 2019 | 02:59 PM
702's Avatar
702
Lots of good info in this thread --- https://www.hdforums.com/forum/touri...libration.html
Old Feb 1, 2019 | 12:59 AM
Joey Mccolloch
6th Gear
Originally Posted by nutsandbolts5212
I did a little research for you, check out these links. It does sound like you have a fuel delivery problem, and I read these links and it sounds as if your MM EFI is junk, my conclusion.
https://www.google.com/url?sa=t&rct=...a_PmW55pUi1PZV
https://www.google.com/url?sa=t&rct=...9d2dhOw3-dDvT1
if the efi was junk it wouldnt run at all
Old Feb 5, 2019 | 09:37 AM
Joey Mccolloch
6th Gear
Sending off to Indy today to see if they can figure out the problem and test fuel pressure will update
BucNastyFlo
Apr 24, 2012 07:18 PM
djcondo
EVO
56
Dec 31, 2011 11:27 AM
Brettfullthrottle
EVO
34
May 12, 2011 08:59 PM
buba6
Exhaust System Topics
May 27, 2010 03:58 PM
robzuc97
20
Sep 26, 2008 01:59 PM
