Replace Lifters?
Old Jan 29, 2019 | 09:08 PM
Dynamick's Avatar
Dynamick
Originally Posted by grbrown
I've owned Harleys for over 40 years and only ever replaced one lifter. I have a dozen of 'em at present (lifters!) and am not about to replace any of them unnecessarily. Where have you read about them blowing up?
Forum member Lauren had a lifter failure take out the engine on her Fat Boy S w/110. And she's far from the only one.
Old Jan 29, 2019 | 09:12 PM
tjcaron's Avatar
tjcaron
i think hers was the story I read that really made me start to think about replacing them.
Anyways, I’m doing it. I also said f*** it and am gonna do cams and pushrods while I’ve got it torn apart.
Old Jan 29, 2019 | 09:51 PM
Bgill's Avatar
Bgill
CVO 110's are notorious for lifter failure due to high spring pressure in combo with the aggressive ramps of the stock 255 cams.
I recently had a lifter start to squeal when hot in traffic at 11k miles so I immediately swapped to the Johnson Hylift lifters mentioned above.
Be sure to get the B2313"SE" version which can be had as low as $110 per set of 4 on HTT.
Also my understanding is S&S is simply a rebranded product so the extra mark-up gets you absolutely nothing but covers their profit margin.
Old Jan 30, 2019 | 05:59 AM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
Anything but stock HD lifter.
Johnson, S&S, GMR, Fueling, Woods, etc, etc.
Unless you still have a ESP, your kinda screwed.
YB
Old Jan 30, 2019 | 06:41 AM
30glock's Avatar
30glock
Definitely do it, mine failed at 24K it took out the 585 cam and oil pump, and some other goodies, 2K in damages covered by ESP but I had the S&S put in, problem solved.
Old Jan 30, 2019 | 10:17 AM
hattitude's Avatar
hattitude
With a Twin Cam engine, I won't make a special trip into the cam chest to change lifters, but if I'm in there for any reason, I replace the lifters AND the inner cam bearings. They are both weak points that have (albeit not in huge numbers) caused failures that can/will be expensive.
With the lifters, anything other than HD "C" lifters will be fine. I never heard a complaint about S&S lifters, but I'm partial to Johnson Hylift, from WFO Larry.
http://www.larrysmotorcyclemachine.com/lifters.html
I use either the 2313SE or newer style 842 SE.
I also always replace the inner cam bearings. The OEM "INA" brand bearings are 23 loose bearings held in place by a cage. There have been some catastrophic failures with these bearings. They can be replaced by Torrington (now called Toyo-Torrington) bearings. They have 31 captive needle bearings, a superior design to the INA bearings.
The bearings are pretty cheap and easy to replace, but you need to buy/rent/borrow a tool for the job. Off the top of my head, I believe you will need B-168 bearings, but double check the number.
Good luck with the work, these twin cams are actually pretty easy, and for me fun, to work on....
Old Jan 30, 2019 | 02:21 PM
tjcaron's Avatar
tjcaron
That's good to know, thanks.
I ordered the Wood TW-7H cam kit from Fuel Moto. Will come with the Wood lifters and FM adjustable pushrods. Your post made me go back and look...it also comes with the bearings. Guess I need to find that tool...
Old Jan 30, 2019 | 02:43 PM
bklynbob's Avatar
bklynbob
Ok ,I’ll be that guy......go in for the lifters and inner cam bearings. Might as well go for a cam and new followers.
Old Jan 30, 2019 | 04:12 PM
470004's Avatar
470004
You are in there anyway, change them and the other items as stated above.
artsbest
Screamin Eagle CVO Models
43
Sep 23, 2017 07:21 PM
TNCarters
Engine Mechanical Topics
May 2, 2017 07:48 PM
skydude426
Feb 17, 2017 08:16 AM
Custardglide
Jan 31, 2016 03:46 PM
jus2anoyu
Dec 8, 2013 07:55 AM
