Cam chest kit
Old Feb 2, 2019 | 10:18 PM
SlingN's Avatar
SlingN
1st Gear
Default Cam chest kit
Have a 06 electra Classic efi. High miles. Stage 1 Do fair amount of 2 up. Not very aggressive rider but like to get up and go too
Looking for a cam chest kit or piece one together. Can’t decide which cams to go with. Crank run out was within spec but not sure I need to go gear drive
any advice is appreciated
Old Feb 2, 2019 | 10:55 PM
Kingglide549's Avatar
Kingglide549
what is the TIR
Old Feb 2, 2019 | 11:28 PM
95th 1200's Avatar
95th 1200
S&S 509 with the Screamin Eagle hydraulic cam plate upgrade and a tune would be a good choice. I had gear drive on my Softail, if I had to do it again I would go hydraulic.
Old Feb 3, 2019 | 12:03 AM
SlingN's Avatar
SlingN
1st Gear
Was done months ago but I believe was .002 or3
Old Feb 3, 2019 | 12:07 AM
Dehammer's Avatar
Dehammer
I wish I could tell you with personal experience how nice it is to eliminate the silly need to concern oneself with perishable plastic parts within an engine. I can't due to my runout being an HD acceptable 0.004".......S&S specs are 0.003". Make sure you measure TIR accurately, especially if using test indicators.
I have S&S Easy Start cams......I like them. My Softail cams wouldn't be ideal for your heavy touring needs.
I can't think of a downside of going gear drive. It is the way it should have came from the factory. I'm just a rider that does not do this as a trade so take my opinion with a grain of salt.
Old Feb 3, 2019 | 05:15 AM
Kingglide549
.003 is for sure OK in the ballpark AFAIK
I know you can jerry reg a Dial indicator up to get a read-...But I finally bought the tool
  1. and it only took about 30 seconds to install it rather than a lot of screwing around.
  2. it gives respectable results and worth the 100 bucks
Old Feb 3, 2019 | 06:41 AM
SlingN's Avatar
SlingN
1st Gear
I’ve never done this before to a bike so I wanna get it right. I’ll check the run out again or my buddy will before I buy anything.
Feuling has a kit more in my price range. But I keep reading there oil pumps are hit or miss.
So if I can’t go kit wise or my runout is to great for gear driven I’m thinking Andrews 26 chain cams. Which oil pump is next question ? And go to hydraulic chain tensioners
​​​​​​ don’t have fhe biggest budget mind you
Old Feb 3, 2019 | 09:51 AM
Kingglide549
The Feueling jig I gives repeatable results every time.
I think it was 106 dollars a year ago.
Old Feb 3, 2019 | 01:21 PM
skydude426's Avatar
skydude426
Just a suggestion, options too look at.
Zippers cam chest heat kit to replace cam support plate, pump and lifters.
https://www.zippersperformance.com/a...t-upgrade.html
Woods TW-222 cams if your leaving the cylinder size and compression ratio as stock.
https://www.fuelmotousa.com/p-28612-...%7Cyear%3D2006
Fuel Moto adjustable push rods.
https://www.fuelmotousa.com/i-208594...%7Cyear%3D2006
Old Feb 3, 2019 | 01:25 PM
95th 1200's Avatar
95th 1200
https://www.harley-davidson.com/stor...l-pump-upgrade
https://www.harley-davidson.com/stor...hrods-18404-08
https://www.harley-davidson.com/stor...ppets-18572-13
You'll also need the rear chain, cams of your choice, inner cam bearings, and to get the bike tuned.
