PackTalk Bold & Bluetooth Issue
I do have the Wireless Headset Interface Module on my Street Glide Special but I am not even pairing my PackTalk Bold to it until I get this issue figured out. I mention this to be clear that the WHIM is not even being used at this point. At least not until I can figure out how to get this basic feature to function properly.
I have "automatic" set on "Audio Call Routing"
Normally, I set the phone to the 1st phone channel, and the WHIM to the 2nd phone channel. When in this position there seems to be a bit of delay when I hit the phone button on the PackTalk and then say "Hey Siri, phone ####". I have hot numbers set in the PackTalk, but haven't tried to use them yet.
Previously, I paired the phone to the Boom, and just used the "talk" button on the bike to initiate a command, and then told the bike to "Call Blah Blah..." and the bike directed the phone. Siri will be gone, but bike commands will work.
note: Be aware that when the PackTalk is paired to the WHIM, you can no longer use DMC. There is a way around this - by setting the WHIM as a GPS - but in doing that you loose mic input to the Boom and can only listen, but DMC will function.
Thank you for the excellent information. I feel like there is not a lot of people who have researched this issue as much as we have and are simply settling for the limited functionality of the headset in these various scenarios.
I have ont have the Settings>Phone>Allow Calls On Other Devices turned off. I thought that only applied to other Apple devices connected to iCloud like an iPad, or MacBook. Did you experience the issue with your bike grabbing the phone cal from the PackTalk? Did disabling the 'Allow Calls On Other Devices' resolve this particular issue?
it just really sucks that some type of functionality is limited in any of the possible scenarios. I don't necessarily care about being able to use the mic from the headset to dictate commands to the bike. This would be great so that I could actually change my destination using voice commands while riding the bike but having Siri to me is more important.
Really, DMC will not work if paired to the WHIM? Although, I have not tested communication using DMC while paired to the WHIM, I have noticed that the light still flashes green to indicate it is in DMC mode.
They make this all way too complicated. These devices should work seamlessly together. I don't know whether to blame Harley Davidson or Cardo.
If you first pair the phone to the headset, and then the headset to the bike, you get dramatically different results than if you first pair the phone to the bike, and then pair the headset to the bike.
NEVER pair the phone to BOTH the headset and the bike.
From my experience, and what I've heard from other riders. FIRST pair the phone to the bike and NOT to the headset, and then pairing the headset to the bike, is the safest first thing to try.
But still watching this too!!!
So has anyone got the Packtalk paired to the WHIM and use the intercom in DMC Mode? Thats what were trying to figure out. Different threads say DMC works with WHIM and some say it doesnt work in DMC.
