2019 Ultra Diagnostics
Old Mar 10, 2019 | 06:13 PM
AlCherry's Avatar
AlCherry
Default 2019 Ultra Diagnostics
For you guys in the know, My electrical manual calls out the HD 50390-1 Breakout Box for diagnostics. My question is, do you need just one box and several overlays and cables, or do you need a different box for the ECM, BCM, ABS, Radio and advanced radio. My next question is are they year specific or generic over several years. I'm not having a problem, but just want to get ahead of the curve if I do have a problem. Thank ahead for the help.
Old Mar 10, 2019 | 06:40 PM
nobodyknowsme's Avatar
nobodyknowsme
Just ride the bike and let your warranty worry about the rest.
Old Mar 10, 2019 | 07:00 PM
AlCherry's Avatar
AlCherry
Thanks for your great contribution.
Old Mar 11, 2019 | 07:52 AM
carlgrover's Avatar
carlgrover
I have an EVO and I got the breakout box for diagnostics. I only need that one box, no additional cables are required. Basically, it is just a way to plug into your bike then you can take voltage measurements across specific areas to check for problems. Obviously, you have to have the service manual to work in conjunction with the box.
I see no reason why a new bike would be any different than mine.
Carl
Old Mar 11, 2019 | 03:33 PM
K Melancon's Avatar
K Melancon
You talking about something else besides the self diagnosistic code you pull up on the odometer?
(Press hold trip reset button turn ignition to run until dis appears then release trip button and cycle through by pressing trip button) different than that?
Old Mar 11, 2019 | 07:29 PM
ORradtech's Avatar
ORradtech
Yes, he is. A breakout box is a tool used to refine/pinpoint the actual problem indicated by the diagnostic codes when more than one fault can cause a particular diagnostic code.
OP, I'm curious where you plan to purchase one. I've kinda looked around and from what I can tell, they're pretty scarce.
Old Mar 11, 2019 | 09:17 PM
Vernal's Avatar
Vernal
Al, In my 2015 EDM there is a section, (1.3) Diagnostic tools. If I’m reading it right there is a box and adapter for instrument module HD 42682. Ecm,BCM , Radio, and ABS 50390-1 and a cable for each one and overlay for BCM and ABS.
I have seen some on eBay made by Kent Moore but I don’t know if they are worth it. If your handy and want a project building one would be much cheaper. Many of the tests done with the Box are open circuit so just checking at the connector would work.
if you do buy one let us know what you get and the cost.
Bill
Old Mar 13, 2019 | 10:44 AM
AlCherry's Avatar
AlCherry
I found the box, overlays and cables on EBay. $600 for everything, NIB. Kent Moore.
Old Mar 13, 2019 | 01:40 PM
bicio's Avatar
bicio
the breakout box needed is one, different cables are instead required for ECM, BCM and so on.
HD do not make them available, aftermarket possibilities are present, example here: https://www.diag4bike.com/us/motorcy...l-diagnostics/
Old Mar 14, 2019 | 02:19 PM
carlgrover's Avatar
carlgrover
I found the p/n for my breakout box in the manual, then googled that number and found a used one from a guy who bought out a dealership to resell the parts. Got it for $175 or $225, I don't remember. Anyway, it's already paid for itself.
carl
Cozz
Audio Systems
Jun 13, 2019 05:08 PM
mlred
Audio Systems
Aug 1, 2018 11:46 AM
14cvoultra
2014-2024 Touring Models
Oct 13, 2014 06:30 PM
flyboyron
Sep 4, 2014 04:42 PM
Nellybelle
May 7, 2008 04:59 PM
