Turn Signal Issues
Old Mar 12, 2019 | 10:02 AM
Tepcro's Avatar
Tepcro
1st Gear
Default Turn Signal Issues
My 2000 FLHTCU-I Electraglide Ultra Classic turn signals work fine when I first start out on a ride...then they just quit working.
All of my bulbs and sockets are ok and I've chased out wiring to be sure I have no shorts...
I seem to always come back to the Turn Signal Module as the problem.
Does anyone have advise about this module? Are there aftermarket replacements?
I am hesitant to buy a "good" use one on Ebay because it may do the same thing.
Any leads on best price and your experience if you've had this problem too would be appreciated.
Old Mar 12, 2019 | 11:52 AM
skinman13's Avatar
skinman13
Could be a heat related failure. The only way you will be totally sure is to replace it.
Have you verified that your charging system and battery are good?
Old Mar 12, 2019 | 08:04 PM
ORradtech's Avatar
ORradtech
Heat related is a good thought.
Were it mine I'd check the temp at the module when it fails. I'd then let it cool and carefully use a heat gun to bring it up to that temp and see if I could make it fail without riding it.
I'd also do some other basic checks like making sure the fuse legs are shiney and, if it has relays, swapping them around
Old Mar 12, 2019 | 08:07 PM
Budda109's Avatar
Budda109
Did you add any LED's? That can be an issue.
Old Mar 12, 2019 | 09:29 PM
Tepcro's Avatar
Tepcro
1st Gear
No I didn’t add or replace with LEDs
the charging system is good and has a new battery....
i dobeieve the module is overheating but can’t prove it...
Anyone know where to get a fair price
The HD part # is 68540-96
Old Mar 12, 2019 | 09:31 PM
nutsandbolts5212's Avatar
nutsandbolts5212
So you checked continuity for the turn signal wires up to the TSM? Did you check for any codes? Is the only malfunction the turn signals or other electrical components? Head lamp working? Fuses? The TSM module is a part I would not buy used either, just saying! I would also use some contact cleaner and clean the connectors.
Ride safe!
Old Mar 12, 2019 | 09:33 PM
nutsandbolts5212
If the TSM fails there would be more electrical components failing as well, like the bike not starting, no flashers, etc...
Ride safe!
Old Mar 12, 2019 | 09:41 PM
Tepcro's Avatar
Tepcro
1st Gear
I don’t have any codes showing... turn signals and emgcy flashers are the only problem.
talked to a HD tech at Buddy Stubbs HD in Anthem AZ today, he said that module failure is a common issue.
But he didn’t have one they cost $150.00
Old Mar 13, 2019 | 09:40 AM
DanRC's Avatar
DanRC
$118 at NewCastleHD.com
Old Mar 13, 2019 | 03:20 PM
Tepcro's Avatar
Tepcro
1st Gear
Thumbs up
Thank You I'll try them!
