Cable length question
Old Mar 20, 2019 | 11:14 AM
partsguynj's Avatar
partsguynj
Default Cable length question
I'm changing the handlebars on my 2006 RK , I'm going with 12" bars ( I haven't decided what brand) . My question is how long over stock length should I go ? Will +4 over stock on the cables and brake line be long enough ? Thanks in advance
Old Mar 20, 2019 | 11:56 AM
grbrown's Avatar
grbrown
Cool
You may get lucky and the brand you chose will recommend the correct length, otherwise to get the best results I suggest you install your bars and then measure. If you buy in advance and get the wrong size you are no better off than waiting!
Old Mar 20, 2019 | 12:16 PM
nutsandbolts5212's Avatar
nutsandbolts5212
Most bars that are 10"-12", the stock clutch/brake cables should be fine, the wires on the other hand, I prefer extending, but you should be able to get by with the stock length.
Ride safe!
Old Mar 20, 2019 | 01:03 PM
caulk04's Avatar
caulk04
If I had to guess, +4 should be fine for a RK. If it were a 'Glide I'd recommend +6.
Old Mar 20, 2019 | 02:22 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
There are a few vids on YT that cover the entire spectrum of changing out the cables and wires for new handlebars. I even think that a couple of them even include a chart or two for those of you that just like to look at the pictures!
Russty__
Sep 20, 2017 09:30 PM
Murphy832
Jun 23, 2017 07:55 AM
glebo
Nov 16, 2012 12:38 PM
BigBrad
Apr 30, 2010 12:06 AM
sharpstick
Aug 30, 2008 03:46 PM
