Hello all!
Old Jul 7, 2007 | 08:19 PM
jwithrow's Avatar
jwithrow
Stage III
Default Hello all!
New here!
I have a 2007 Ultra. The bike ran fine until today. It was around 90+ outside and the bike did not want to idle when coming up to a stoplight. I have a race tuner and changed by idle rpm from 800 to 900 and it did not really help.
Any ideas???
Old Jul 7, 2007 | 08:32 PM
Tech2's Avatar
Tech2
Default RE: Hello all!
Did it stall?...or just run rough?
I thought the PCMs on '07s were programmed to shut down the rear cylinder at idle when the engine temperature got too high, which might explain a rough idle. Maybe somebody else can confirm this.
Old Jul 7, 2007 | 08:42 PM
jwithrow's Avatar
jwithrow
Stage III
thanks for the help. it stalls when I come to at stop. i have the temp management turned off with the race tuner software.
Old Jul 8, 2007 | 04:26 AM
PapaTravis's Avatar
PapaTravis
First off, welcome to the forum. I have a '05 with a carb, so I can't really help you out, but I am sure someone here can point you in the right direction. Have you talked to anyone at the dealer that installed the SERT? That would be my next stop. Also, is it only at idle? Could it be bad gas? Just throwing out options.
Old Jul 8, 2007 | 05:34 AM
Ben U
Guest
Posts: n/a
I had a race tuner installed after I put on my Rush pipes and stage 1, it ran fine for about two weeks and then started running like crap. It had a rough idle and stalled a few times. I took it back in and they found a problem with the tuner, they took it off, installed the upgraded download for my configuration, and refunded my money. No problems since.
ultraclassic53
May 9, 2015 12:39 AM
jrsuperfrog
Jul 3, 2014 08:58 AM
JMHVAC
2014-2024 Touring Models
Jun 11, 2014 05:39 PM
birdmandave
Sep 29, 2012 07:39 AM
racinjason
Jul 1, 2009 05:32 PM
