Doggone Ride Planner
Old Apr 11, 2019 | 05:40 PM
Michael Haz's Avatar
Michael Haz
Originally Posted by Rocket67
You need to change your destinations to Waypoints and it will load it all as one route.
Thanks. I did this and it worked. Now the entire ride shows up on the Nav display, with my previous destinations now converted to waypoints.
Old Apr 11, 2019 | 09:09 PM
tbrtt1's Avatar
tbrtt1
I have seen it do that. I don't know why but for some reason it will double back when you drag a route to another road. I have been able to play with it until that goes away but what a PITA glitch.
If it is a 4 lane or more road you may have to zoom in to make sure you have it on the proper side of the street. So if your rout is generally going east to west and you drag a part of it to a another road and plop it on the east bound side it will cause that. That has save me some frustration once I figured that out. Also, if i am not familiar with the area, I have clicked on a one way and gotten a strang double back. For the most part, once getting past the learning curve, I love the convenience of mapping out a route, having it automatically on my phone and having it easily get to the BB GTS from my phone.
Old Apr 11, 2019 | 09:37 PM
Hammz's Avatar
Hammz
It's not the ride planner that breaks up the route, its the Harley Boom GTS Navigation system. Also, HD locations are stored in the Boom Nav, not in the route itself. When you do updates to your Nav system HD locations are part of the update.
Ride Planner DOES break up the route. Every destination to next destination is a separate route within the Ride Planner GPX file. If you want the Ride Planner GPX file to contain just a single route, all intermediate destinations must be converted to waypoints before saving/exporting. This is as designed. You can see this when importing a Ride Planner GPX file: you are given a choice to enter just the first route (file name) or you can select ALL & then select the individual routes that were imported from the same GPX file.
Old Apr 12, 2019 | 07:50 AM
TexasMotorcycleRider's Avatar
I used to load them in my Garmin and it didn't break out the route. Even if you use the app for navigation it will keep it at one route. That being said, I see what you are saying and agree it is the gpx file that causes the Nav to break it to separate routes. That is why it needs to be changed to waypoints.
Old Apr 12, 2019 | 07:51 AM
I usually zoom in pretty close but will double check next time I come across that issue.
Old Apr 12, 2019 | 07:52 AM
Awesome!
Old Apr 12, 2019 | 09:12 AM
Crabchuck's Avatar
Crabchuck
After a horrible experience with the point to point segmentation last year, I've been playing with the planner and using waypoints to get to the roads I want to ride. Predicting the behavior isn't fun. For example, I'm trying to plan a long ride. So waypoints to force the desired route will work. But, it's not single session ride. There will be stops for biobreaks, food, fuel, etc. So what happens? Does it restart automatically? Do you have to restart the trip and then remember how many waypoints you are into it so you can skip them and it won't route you back? I've been trying to do some little short rides around home to try and figure this all out, but it's not been going well.
Old Apr 12, 2019 | 09:38 AM
tbrtt1's Avatar
tbrtt1
When you stop it should pick up where you left off. You may get a "recalculating" message when pulling over and when getting back on the road, but I haven't had a problem with that. The other option is to pause the ride/route when you stop. WHen you start back up it should pick up where you left off.
I made a couple trips from home (Houston area) to Baton Rouge recently to see family. I put in my destination and simply took whatever route I wanted. I didn't need directions since I know where I was going but I wanted the stats from the trip. When I arrived I could see how long it took, how many stops I made, the average MPH and MPG, etc. One thing to consider is if you stop to get get gas at the pump then pull into a parking space to take an extended break it will count that as 2 stops since you are technically starting and stopping twice. I like to put the ride on pause for this as I approach my stopping point.
I know, kinda geeky, but I like to see the number of stops etc and an accurate average speed for the trip. Helps me get an idea of how long and how many stops to plan for on extended trips. First bike I have had that had these fancy bells and whistles!
Old Apr 12, 2019 | 12:29 PM
Crabchuck's Avatar
Crabchuck
I just want to make sure I understand how to use the tool. I think I goofed and I picked a destination other than a "trip" because I never got a waypoint. Since I wrote my previous post, I've created 3 different test rides just around my neighborhood so I know exactly where the waypoints and turns are and can focus on what the system is doing.
Old Apr 12, 2019 | 02:38 PM
Dark Knight's Avatar
Dark Knight
i have the same concern with a trip that I’m planning and how it’s going to pick back up on the route after I stop for lunch. I decided to play it safe and break that day up into two routes as we all know that there are few things more frustrating than dealing with non-cooperating GPS in the middle of a big trip. Been there, done that.
