Understanding the need for new shocks.
There seems to be two factions of Harley riders. Ones that wrench on their own bikes understand what changing parts does to the performance and those that drop it off at the dealer and have them install parts expecting the changes to be optimal with little understanding of how things work. Nothing wrong with either approach but people need to be honest with their expectations.
I road over 49K miles on my '78 FXS before it got stolen, and then put about 90K miles on my '80 FXS before selling it..... I rode those bikes all over the place..... for about 4 years, those bikes were my only transportation here in SoCal.... I was younger, but never once gave a thought to changing the suspension......
Then I bought a '12 Limited, drove it across country, and knew I needed something different for shocks.....
I believe age, model of bike, and riding use/style will greatly affect what you expect from and will ultimately want from your suspension...
I have read quite a bit here about replacement shocks, but how do I know if I need them?
I am not new to motorcycling, but I am new to Harleys. I own a 2017 SGS. I bought it from the dealer's rental fleet in September of 2017 with 11,600 miles on it.
I am 6', 240 lbs., and I ride solo. In fact, I just bought a Mustang Super Touring Solo for the bike. My riding is mainly local - highways and byways in the Raleigh area of North Carolina. I plan to take some trips up the mountains here.
Since I am riding my first Harley, what am I looking for in terms of the need for replacement? Just because I am riding on the stock shocks should not be reason enough to replace them. For what it's worth, the service guy at my local HD dealer recommends the Progressives as best bang for the buck (should I decide to replace the shocks).
Thank you.
Thank you.
I wrench on my bike and I happen to be very mechanically inclined. I am also picky to a fault.
That said, I have tried many aftermarket shocks; pro-action, Progressive 444s, Super Shox, Legend Revo-As to name a few.
I adjusted all of them a thousand different ways while working along with the manufactures. I do understand what the various adjustments available on a given shock can do.
None of them provided a perfect ride or I should say, the ride I was looking for. There always seemed to be that bump in the road that rattled your bones. Therefore, since I can get that type of ride from stock shocks, I felt I was wasting my time and money with those so called high end shocks.
Im currently riding with 13 HD hand adjustables.
They ride stiff even at the softest preload setting. Am I happy, no! I persevere since at least they dont bottom out. Lol
My style of riding is not to carve canyons. I like to cruise at the speed limit and enjoy the sites and smells and of course the ride.
I think my old 1977, 750 Honda that I purchased new rode better. Of course I was a lot younger then and my perspective has probably changed.
Here is a quote I am stealing that explains it better than I can put into words.
"When selecting a spring rate remember that a firm spring rate will not make a bike ride “Stiff”. In fact a firmer rate with less pre load gives a plusher ride than a softer rate with more preload. Spring rates and preload will determine the range of stroke that the bike uses. Soft rates allow the chassis to ride deeper into the suspension travel and therefore into the stiffer part of the stroke. (Leverage ratio curve for the geeks). If you are on the fringe of the spring rate range, don’t be afraid to select the firmer rate."
So with most of the shocks that are available under the 1K price we are living with what ever compression setting the engineers came up with. Some can have the compression valving changed if you send them back to the manufacturer. We also dont have much stroke to use, the deeper in the stroke you go the compression gets stiffer.
Hopefully this will help some if you are having a set of shocks built for you.
In short, there are gains to be had with aftermarket suspension, whether you realize it or not. You won't get razor sharp handling from a bike that has a pillow type ride, there are trade offs.
Thanks again, look forward to more results. Telemetry is key when doing the testing, I was just starting to get into it when I retired from racing as my two sponsors Mastercard and Visa ran out of funding !
Craig
Yep, objective, repeatable testing really makes everything much easier. While our personal experience of comfort, compliance, stability, is important, it can also be swayed by many factors....bias for or against a company, if we got a good nights sleep, mood, etc, etc. But the machine is going to give unbiased results each time...PLUS show what adjustments make what differences, better or worse.
Oh, regarding the True-Track. We've used it on bikes in the past, also the Ride-Str8 system. However, on 09 and up baggers, with the frame change, we've not found those necessary.
Test bikes have been '11 Tri, '14 Tri, 14 Street Glide, 16 Road Glide, 15 Road King, '12 Softail Heritage, '09 Sporty, '10 Sporty, '15 Sporty, '13 Dyna, '01 Dyna. The next round of testing will include many of the previous bikes, plus a '19 Tri, '18 Softail, '18 Road Glide and possibly a couple of more.
Last time we did testing we thought we'd be done in a month or so, and it ended up taking over a year! I'm hoping we can be done before the fall, but we will probably release results as we get them.
DKCustomProducts.com
