‘07 Ultra gearing question...
Old Apr 17, 2019 | 04:57 PM
Essthreetee's Avatar
Essthreetee
Default ‘07 Ultra gearing question...
So I have been hearing all this stuff about ‘07 6-speeds being geared wrong. It got me to thinking that maybe one of the previous owners of my bike (I am the 3rd) has re-geared it.
I know now that it has had a belt replacement somewhere in its life...but for those that know, what RPM does a stock bike run in 6th gear at 70 mph? My bike is around 2500 rpm.
Old Apr 17, 2019 | 05:13 PM
pei_guy's Avatar
pei_guy
My 08 is revs around there too. Gotta be doing 80 or so to be bothered putting it in 6th.
Old Apr 17, 2019 | 05:23 PM
Zerk's Avatar
Zerk
I might be in manual if you look. Not sure. I kinda doubt it has been changed. It is not that common of mod.
Old Apr 18, 2019 | 05:21 AM
caulk04's Avatar
caulk04
07 and 08 had the taller gearing. I never minded it on my 08 bike, in fact when I started riding this 11 I wondered why it was revving more...didn't know the gearing was shorter at first.
If you want to be sure, just go count the teeth on your rear sprocket. The front could also be different, of course, but it's harder to count and less likely to have been changed.
32/66 for the earlier bikes, 32/68 for later.
Old Apr 18, 2019 | 05:53 AM
dawg's Avatar
dawg
On my 08 I changed the gearing by doing the 49 tooth ring gear conversion at the clutch basket.
Old Apr 18, 2019 | 07:11 AM
Zerk's Avatar
Zerk
Are you what years they changed? I have heard conflicting things.
Old Apr 18, 2019 | 10:09 AM
AlCherry's Avatar
AlCherry
The '07 & '08 FLHTC/U 96"were geared the same. 6th gear @ 70mph (2450 rpm) lugged the motor and delivered poor fuel economy, 38-40 mpg, poor passing ability along with a host of other problems associated with lugging a engine. I found on mine, running in 5th at at 70 mph, 2900 rpm the stock 96 performed well. I regularly got 48-52 mpg, pulling hills and passing were great. I didn't use 6th gear until I wanted to run 75 mph or higher.
Old Apr 18, 2019 | 10:26 AM
dafrisco's Avatar
dafrisco
Default 2007 gearing
I have a 2007 FLHTC and now I know why I can only get 38 mpg in 6th gear. I will see about running in 5th for awhile and see what that does to me mileage.
thanks for the tip
Old Apr 18, 2019 | 12:10 PM
RevBlk's Avatar
RevBlk
Or change your rear pulley to a Jap sportster one which I did. Gives you the same overall gearing as an 09+
Old Apr 18, 2019 | 09:20 PM
Seahorse's Avatar
Seahorse
My 07 has a 70 tooth rear pulley. Do you know the part number or tooth count for the sportster pulley?
