it like you already have all the info. What else do you need to know
Thanks for responding decencyxdefied.
I knew these weren't the 4" mufflers, but after that, I wasn't sure. Were they the Xtreme bundle or just separate pipes from mufflers or maybe I was totally off base and they were an old 3" version or something like that.
I just thought I'd throw this out there as you folks are WAY more knowledgeable about these things.
I'm not a motorcycle newbie, but I am a Harley newbie. Although, I'm learning fast from experience and ingesting forum knowledge.
The header off the rear jug of the Rinehart "True Duals" that I have flips right back under the seat and then over top the primary towards the back. Those pipe you have there look as though they have an under the bike crossover pipe and I don't think Rinehart makes pipes that do that except for the Xtreme Duals and those aren't them. https://rinehartracing.com/product/xtreme-true-duals/
You're correct that the slip-ons are not 4", they are the 3-1/2", which I like better than the 4", myself.
Reason: Did some research.......
