Stuck push rod
Old May 10, 2019 | 08:15 PM
Ironbyrd81's Avatar
Ironbyrd81
Default Stuck push rod
Had a louder than normal ticking sound coming from front cylinder. So I took off the rockers and when I went to pull out the pushrods the intake one was stuck inside of the lifter. I had to yank pretty hard to get it out.
Any thoughts on what would cause that? They are fairly new S&S lifters and S&S adjustable pushrods.
This is the 96” engine.
Old May 10, 2019 | 09:30 PM
skydude426's Avatar
skydude426
Lack of oil and they started to fuse together?
Old May 10, 2019 | 09:34 PM
Ironbyrd81's Avatar
Ironbyrd81
Plenty of oil on it when I yanked it out and the lifter has lots of oil as well.
Old May 10, 2019 | 09:41 PM
internet troll's Avatar
internet troll
Set too long and bent. That would also explain the ticking.
Old May 10, 2019 | 11:06 PM
Ironbyrd81's Avatar
Ironbyrd81
You mean the length of the adjustable? If so it was 4 complete turns per S&S instructions. Is there a sure fire way to see if it’s bent?
Old May 10, 2019 | 11:50 PM
hattitude's Avatar
hattitude
Roll it on a known, flat surface......... you'll be able to tell if it's bent or not....
I'm curious, as I have never heard of a pushrod stuck in a lifter. Was the lifter collapsed? Did you take it apart to see if any internals were broken? Can you tell how it was "stuck" in the lifter?
As far as the pushrod goes, I bought an '01 softail recently with only 9.8K miles. It had a slight tick from the rear cylinder. When I inspected it, I saw the intake push rod cover moving... uh-oh..
Here's what I found..
So a bent pushrod can cause a ticking sound, but I'd guess yours was a failed lifter.... S&S makes good lifters, but hey, even good manufacturers have a few failures now and then..
Old May 11, 2019 | 12:30 AM
23Seven's Avatar
23Seven
I was thinking maybe that pushrod was extended out too far? Hopefully it didn't mess up anything else.
Old May 11, 2019 | 09:21 AM
Screamin beagle's Avatar
Screamin beagle
Did you pull the cam cover yet? Why did you remove the rocker cover to take out an adjustable push rod? Just wondering.
Old May 11, 2019 | 09:28 AM
skinman13's Avatar
skinman13
I recently replaced a new set of S&S performance lifters with less than 3K miles on them because I could not get the front intake to stop ticking and performance issues at higher rpms. I was not sure if it was the lifter or the older used SE adjustable pushrods I installed so I replaced it all with new SE performance lifters and SE taper adjustable pushrods...problem solved. I could not see anything wrong with the pushrods so I believe it was the S&S lifters at fault.
Ironbyrd81's Avatar
Ironbyrd81
I have not removed the cam cover yet, I wanted to remove the rocker covers just to check everything. Plus I think the adjustable pushrods are still easier to remove through rocker then to try to take the lifter cover off. I have never been able to get the pushrods back in that way.
Curious why ask if I remove the cam cover? Should I?
