Help Finding Part Number Please
Old May 15, 2019 | 10:45 PM
Bodacious MC's Avatar
Bodacious MC
Default Help Finding Part Number Please
I have a 2014 SGS. The OEM License plate light is a LED sealed unit. Can't seem to locate it at Ronnies or boardtracker parts fiche. It is located within the rear Tribar assembly. This is a Can-bus chassis.
Appreciate if someone can get pointed in the right direction.
Thanks
I tried in the Rushmore forum with no responses.
Old May 16, 2019 | 08:15 AM
GalvTexGuy's Avatar
GalvTexGuy
The license plate light is not serviceable. Now, if you're one of those who can micro-solder and you're willing to try disassembling the unit, it's probably doable if you can find a suitable replacement LED.
Old May 16, 2019 | 09:55 AM
Bodacious MC
Thanks. My problem is that the running lights work fine but the license LED light stopped. Am I correct in thinking that the power source is good to the assembly and just the LED unit went bad?. I don't completely understand how the Can-Bus distributes voltages .Hoping not to buy a complete assembly and find out that the power source is not there.
Thanks much!
Old May 16, 2019 | 02:49 PM
GalvTexGuy's Avatar
GalvTexGuy
Thanks much!
This is from the wiring diagram for your bike. You can see there is a Facia/Converter Module that is in the circuit to the light bar. Don't ask me how you troubleshoot to see if there is or is not power coming from the module. That's way above my paygrade. Maybe the Touring Electrical Diagnostic Manual has that information. Unfortunately, I don't have that manual.
Old May 16, 2019 | 04:26 PM
Bodacious MC
Nice engineering HD. Broken license plate light and replace the entire tri- bar assembly.
Oh well.
Old May 17, 2019 | 09:53 AM
grbrown's Avatar
grbrown
Red face
I'm not familiar with your bike, however as an engineer I firmly believe that what man has made he can repair - someone out there knows how to fix that darned thing for ya!
Old May 17, 2019 | 11:35 AM
Steve N,'s Avatar
Steve N,
I don't have a Street Glide to take a look-see, but would this be the part number that you're looking for? Ref# 36 Part #73254-10 at
https://shop.outpostalaska.com/OEMpa...P_&_TURN_SIG/y
Old May 17, 2019 | 11:58 AM
GalvTexGuy's Avatar
GalvTexGuy
Not sure if that part will work with his bike. It's an HDI (international) part, not domestic.
Old May 21, 2019 | 09:01 PM
Bodacious MC
Thanks, but $69.36 for a license plate light....ouch. Might start looking for a take off used Tri-Bar light assembly?
Old May 23, 2019 | 05:35 AM
Toe Knee's Avatar
Toe Knee
Changing the Tribar light might or might not fix your issue.
it goes Main Harness>>>tribar>>>bullet lights and plate light.
It could be the tribar, the harness to the plate light or the plate light.
You're in the same bind as me......I have a SG/RG rear set up with no brake lights.....I either have a bad rear harness, or tri bar.....I can't seem to hook up with anyone to let me use their bike to trouble shoot it.
