Tuner help
Old May 18, 2019 | 05:07 PM
23Seven's Avatar
23Seven
Originally Posted by 2slow05
i will check them out and give them a call. You think those two cams are a good bit better vs the 255? Only reason i looked at the 255 cam was the price around 150 for a set of take outs.
48’s are decently priced and probably the most popular Cam for a stock 96 incher.
The entire kit can be had for just over $600.
Cam only is $250.
I would go with the whole kit with 50,000 on your clock.
Adjustable Pushrods make the job easier, no need to pull rocket boxes. Lifters are top notch woods night prowlers and quieted Down my top end a little, plus at 50k you probably need new ones anyway. Also upgraded bearings are much better than OEM. Gasket kit is top notch as well.
I would see about a deal if you get the PV Tuner as well.
Sorry for spending your cash but it is a great setup.
Old May 18, 2019 | 05:13 PM
23Seven's Avatar
23Seven
Sorry didn’t answer your question...
Yes I think the 48’s and 222’s are better bagger Cams than 255’s.
Old May 19, 2019 | 09:59 AM
Tired's Avatar
Tired
I agree with 23. Andrews 48's are a great choice for what you want to do.
Old May 19, 2019 | 07:35 PM
2slow05's Avatar
2slow05
thanks guys i will look into those. Is there anything i need to do to the oil pump since i am in there? I dont think i have a problem but with the bike at idle the pressure is like 5-7 psi and when on the throttle it goes up to 30psi or so
Old May 19, 2019 | 08:08 PM
23Seven's Avatar
23Seven
Not sure where PSI should be at idle.
What is your idle set at?
Old May 20, 2019 | 10:54 AM
2slow05's Avatar
2slow05
My bike idles around 1000 rpm maybe a little less
Old May 20, 2019 | 03:42 PM
23Seven's Avatar
23Seven
Thats plenty of RPM’s to keep the oil moving.
Old May 20, 2019 | 03:51 PM
cprhed's Avatar
cprhed
If you have the box the cable kit is easily ordered.
The tuner you have is the right one you need. I have the SE255 in mine with the 103 kit. maybe I missed it but didn't see if yours is stock 96 or not. The cam is really good. 6th gear is crap in these things stock. The cam will really help wake it up.
As suggested, make sure you get a good dyno tuner to do it for you. You can download the software and mess with it yourself but it is a guessing game without being able to truly run it.
Old May 20, 2019 | 04:39 PM
2slow05's Avatar
2slow05
yeah it is usually around 7-10 psi at idle and when riding usually around 30psi on the pressure
Old May 20, 2019 | 04:40 PM
2slow05's Avatar
2slow05
i do have the box but unfortanetly i cannot read it since it got wet 1 time, i think to be able to load the program on computer i will need the serial number from the device and i cant read that from the box
