Tuner help
Old May 17, 2019 | 05:33 PM
2slow05's Avatar
2slow05
Default Tuner help
I bought a used 2008 harley ultra with rhineheart exhaust and it has a tune on it. The part number on it is 32109-08A which tells me that it is a Screaming eagle pro super tuner. I am thinking about changing my cams to to SE255 and i know i will have to change the tune as well. Can this tuner be updated so i can tune my bike after i change the cams? If so how can i do it or will i have to take it to the dealer and let them dyno tune it?
Thanks for the replies, i did do some searching and cant find what i am looking for, there is multiple thread on tuning and the different SE tuners and was kinda confused between the different ones.
Old May 17, 2019 | 05:58 PM
dawg's Avatar
dawg
Did you also receive the following:
32111-12 CD
32184-08 Cable kit
32101-08 Tuner training DVD
If you have the above items you should be able to tune it after you change the cams. However, a dyno is best.
Old May 17, 2019 | 06:06 PM
2slow05's Avatar
2slow05
32111-12 CD
32184-08 Cable kit
no i didnt get that, i will send the guy i purchased it from a message and see if it has it. If not can it be sourced? Also if i had that can you buy tunes from companies and load it that way or do you have to write your own tune. I have tuned trucks before by loaded tunes from company on my device then load it on the vehicle.
Old May 17, 2019 | 06:11 PM
dawg's Avatar
dawg
I know the cable kit is still available at dealers, has an -08A part number now. I’m sure you could find the CD and training DVD on eBay. The guy that had the bike probably had a dealer tune it so he didn’t have the cable kit and tuning software. You should be able to load a canned map if you have the software and cables.
Old May 17, 2019 | 07:37 PM
2slow05's Avatar
2slow05
can the software be downloaded from the website at
http://streetperformancetuner.harley...reetTuner.aspx
or is my tuner too old to use that?
Old May 18, 2019 | 07:49 AM
leachman's Avatar
leachman
I have the same bike and the same cams and I highly suggest a good dyno tuner....Up here in the East the person to go to is Robs Dyno Service...
Old May 18, 2019 | 08:12 AM
Tired's Avatar
Tired
You don't state what your goals are with your planned cam swap but you might shop around a bit more. Unless you're in love with the school bus cams you mentioned.
Old May 18, 2019 | 10:33 AM
2slow05's Avatar
2slow05
Since I ride 2-up mostly I want more lower to mid range torque and I barely see any rpms above 4500-5000. I would like to accelerate faster and pull harder on the low end and going up hills. I don’t want to have to downshift as much or lug the motor. If there is some better options out there let me know and I will for sure look into them. I will be doing the work myself as far as the swap. Also my bike has 50k miles on it and what all should I replace or upgrade while I have the cam plate open?
Old May 18, 2019 | 02:11 PM
23Seven's Avatar
23Seven
Fuel Moto.... Give em call.
Cam kits include Lifters, Push Rods, Inner Bearings, Cams, and all gaskets To button it back up.
Might have s deal on a Powervision with the kit?
Read up on Andrews 48’s and Woods 222 Cams as I think they will meet your needs.
I went with the 48 kit and love them for 2 up riding. They are great down low and still pull all the way to 6200 if you feel like hot rodding. Just recently added a Jackpot 2:1 exhaust and found some more low end grunt.
Call Jamie at Fuel Moto and he’ll point you in the right direction.
Old May 18, 2019 | 04:10 PM
2slow05's Avatar
2slow05
i will check them out and give them a call. You think those two cams are a good bit better vs the 255? Only reason i looked at the 255 cam was the price around 150 for a set of take outs.
