Paul Yaffe Stealth 3 Install - HELP!
I am at the part in the instructions where it tells you to remove that silver plate underneath the fender and drill out the two bungs using a 1/4" drill bit. It does not explain how to remove the silver, triangular plate from the fender. There does not appear to be anything holding the plate to the fender so I am assuming it is some type of 3M tape or adhesive. However, before ripping and prying it off, I want to ask you guys how you got it off.
I thought I would try to use the two stock screws but they did not fit in the two back holes on the license plate frame. I tried all the screw sets that came with the Steath 3, why are there 3 different sets anyway?, but they do not fit through the bungs on that silver plate. Is there an easier way than having to remove the plate?
Please help. I am stuck and want to ride tomorrow but I don't feel like throwing the stock light and frame back on the bike.
I didn't fee l comfortable drilling them out while the plate was attached. I can guarantee, I would have allowed the drill bit to slip or accidentally touch the metal shavings and scratched my fender for sure.
I took it to my local dealer and without even talking to him, he thought it was easiest to drill them out with the plate attached. I asked him after he did it and he said he has done this install quite a few times and had not issue drilling them out. It looks pretty good.
I wish they made it more clear in the instructions. One step simply says that the bungs need to be drilled out and the next step shows the plate removed with someone drilling them out. It doesn't mention how to remove that plate at all. I did confirm with my tech that the plate is attached to the underside of the fender with some type of 3M adhesive. He said it is a pain to remove.
A replacement plate costs $20 for those that are willing to try removing it.
Thank you for your response.
