Oil filter???
Old May 21, 2019 | 07:58 PM
1Canuck's Avatar
1Canuck
Originally Posted by Tired
True 5 micron? Depends on what your meaning of true is. If you dig far enough, that 5 micron advertising claim means 5 micron nominal, not absolute. Meaning it will pass a lot of larger than 5 micron particles. If it was absolute it would plug up fast and bypass. In any case, JMO but I wouldn't be afraid to use any reputable filter designed for the application.
I've been using WIX for years myself.
Exactly. Many years ago I did the research and not going to do it again. The HD filter IIRC is made by wix or fram (then). The 5 micron filter was like 5% of the time (nominal). Anyway, others that also claim 5 mic nominal allow larger size. In the end I went with a stainless 25 micron 100% of the time reusable filter which in studies filters better overall than all the 5 mic ones. Let the bashing begin, not going to defend.
Old May 21, 2019 | 08:16 PM
Campy Roadie's Avatar
Campy Roadie
Originally Posted by 702
WIX for me, 5 micron and designed for HD MC's. Local parts houses stock them, or Amazon has them for around $7.
http://www.wixfilters.com/Lookup/Par...x?Part=1721791
That ^
K&N isn't made in the USA anymore. The quality has slipped from where it was when Champion Labs made them in Illinois.
Old May 21, 2019 | 09:33 PM
Mertoid's Avatar
Mertoid
I use the mesh filters also. Their filter media is not hit and miss like the paper filters.
Old May 22, 2019 | 06:38 AM
Brewmany's Avatar
Brewmany
T........... In any case, JMO but I wouldn't be afraid to use any reputable filter designed for the application.
Because they all do what they are designed to do. I've yet to read about someone who's "had issues" because their filter media was wonky.
IMHO they are more the same than they are different.
The only problems I read about here are leaks around the base of the filter and the inability to remove a stuck one.
And the never ending debate on which filter is "the best"- whatever that means.
Old May 22, 2019 | 07:32 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
An Advance Auto I shop at has several filters with the outer cans cut off. Interesting. Fram media looks like some type of cardboard.
Most look fairly decent, I quit using frams on anything. In fact, I cross referenced it to an AC Oil Filter for the same price online and much mo betta!
Old May 22, 2019 | 07:45 AM
xcbullet's Avatar
xcbullet
I use AC on the cages but can't put a blue filter on the bike.
Old May 22, 2019 | 07:52 AM
bigal51's Avatar
bigal51
Been using D2w Moto filters for a couple of years, no problems.
Old May 22, 2019 | 08:49 AM
Sturgis67's Avatar
Sturgis67
Thanks everyone for all of the input, didn’t intend to start another oil/filter debate, just trying these out and seeing if input was positive.
Ride safe!
Old May 22, 2019 | 09:45 AM
Brewmany's Avatar
Brewmany
Ride safe!
You didn't start a new debate, this is just a continuation of the same debate that has been going on ever since they invented the oil filter. It'll continue on long after this thread dies.
Old May 22, 2019 | 11:24 AM
Campy Roadie
There's first hand experience right there ^.
Side note:
Is it "big al 51" or "bi gal 51" ? Just kidding around Al
