Aligning Ignition housing
Old May 25, 2019 | 10:04 PM
Kevin Spencer's Avatar
Kevin Spencer
3rd Gear
Default Aligning Ignition housing
Had to take ignition out to replace a twist grip sensor, all's well until I go to slide the ignition into the housing, following for badem the lock position, 4th position and the button on the lock, NOPE wont slide in,
Research and found there's a tool to re-align the ignition MY ? Is , Is there any other option rather than spending $40-$90 bucks on this "tool" anybody ever make one?
Old May 25, 2019 | 10:48 PM
decencyxdefied's Avatar
decencyxdefied
There are threads on here with diy tools.. Vids on YouTube as well
Old May 26, 2019 | 08:13 AM
memphisharley's Avatar
memphisharley
Old May 26, 2019 | 11:17 AM
Kevin Spencer
3rd Gear
Default Thanks
Thank you
Old May 28, 2019 | 07:46 AM
roadkil1995's Avatar
roadkil1995
I always just use a large flat tip screwdriver.
Old May 28, 2019 | 07:49 AM
sanman4ever's Avatar
sanman4ever
I just did a fork job yesterday. I've used a screw driver and PVC pipe many times. Yesterday was the first time I used the HD alignment tool and a seal driver. What a difference using both of these tools designed to do a specific job.
Old May 28, 2019 | 08:02 AM
decencyxdefied
same here
Just Me
Mar 8, 2015 05:11 PM
kryingame
Sep 14, 2013 10:50 PM
flhxmc
Feb 22, 2013 09:53 AM
Terp84Alum
Jun 9, 2010 06:03 AM
marcparnes
Jan 1, 2010 10:29 AM
