Air Shock Issues
Old May 27, 2019 | 08:29 PM
PapaHux's Avatar
PapaHux
Stage III
Default Air Shock Issues
2013 FLHP. Shocks had no air and road like a log truck. Added 20 lbs. and still rides bad. Had an Ultra Classic (97) with no issues. Any thoughts?
Old May 27, 2019 | 09:08 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Try 30 lbs. How much do you weigh?
Old May 27, 2019 | 09:23 PM
caulk04's Avatar
caulk04
Keep trying. I run 30lb in mine usually and will still hit the stops on the right dip. 290lb rider with tour pak.
Old May 27, 2019 | 09:43 PM
PapaHux's Avatar
PapaHux
Stage III
190 lbs.
Old May 27, 2019 | 11:43 PM
OldEnuf2NoBtr
Originally Posted by PapaHux
190 lbs.
Go up to 30 #'s, then 35 #'s if need be.
Old May 28, 2019 | 06:05 AM
alarmdoug's Avatar
alarmdoug
I inflate to 50 Lbs in my 14 RK.
Me - 180LBS, Wife 120.
Old May 28, 2019 | 07:16 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Spray soapy water solution on air lines and connections, look for leak.
Is the bike lifting any at all when you add air?
Do not exceed max psi for your system.
As you know, goal is 1" of sag (Drop) in suspension as you and yours sit on the bike.
Trial and error, you will find what works for you and your system.
Using the HD Shock pump?
Here's a simple video:
Old May 28, 2019 | 07:17 AM
Cogswell's Avatar
Cogswell
As others have said, increase the air pressure gradually until you find your happy spot. Changing the oil in the air shocks helped improve the ride on mine significantly as well.
Old May 28, 2019 | 08:33 AM
caulk04's Avatar
caulk04
I forgot to mention this as well, I do have heavier oil in my shocks. I forget off the top of my head the weight, but it's done quite a bit to slow down the motions of the suspension since we're so heavy. It does nothing for ride height and travel, but it lets the shock absorb more in its short travel.
drmccarty
Air Suspensions
Apr 27, 2016 08:39 AM
Raxus
Aug 12, 2013 02:36 PM
prezflyr
Apr 14, 2013 11:29 PM
FL-kruzen
Jan 4, 2012 01:05 AM
Thunderchild
Mar 17, 2008 10:52 AM
