I've come to the unavoidable conclusion that "it's a Harley", and not much you can do about it.
The first part of that statement is true, but not the second part! Travelling at high speed changes the dynamics of a vehicle, obviously, but there are a few things we can do: simple stuff; adding carefully chosen extras; serious upgrades.
The simple stuff is to use high quality tyres, but especially set the pressures correctly. Add a little extra air for high speeds, also adjust them further to suit your weight. If you are a heavy chap, add a little extra pressure. Numbers could be an extra 2psi in each tyre, for each of those conditions, in other words up to 4psi extra. Experiment a little, to get things 'just so'.
The next step is to use a stabiliser kit. True-Track is my preferred brand, to tighten up handling and stability.
Upgrade your suspension, front and rear, to a superior brand such as Ohlins.
As mentioned by most it was the steering bearings that needed to be adjusted/tightened. My tech said they were loose and its very common. He also said he has had very good success with going one tighten further then Harley specs if that helps anyone.
He he mentioned that a stabilizer isnt real necessary but would not hurt. In all of my countless hours of research I havent found a company that makes a full from system for 17 and new touring models.
It would be worth contacting True-Track. They are the original makers of such things, copied my many other brands, and still make kits for more models than the others.
All great points...not sure if this is even a factor since you didn't mention it but i recently saw a video on wobbles and another cause i discovered is if you load too much weight on the rear of the bike it can cause the front to lift and create the wobble. If your saddle bags are loaded to the hilt, and you're perhaps a bigger guy who leans back in the saddle and maybe strap a bag to the rear, use a full tour pak, or do two up riding with heavy packed bags....just thought it was worth mentioning.
Yes, it is common and not limited to touring models either. The neck bearings on my 17 Heritage were loose from the factory. It didnt wobble but it did have a clunk when going over bumps. I took it to my independent mechanic and he was shocked how loose they were.
****edit**** looks like you solved your problem!
Good comments. A weakness of H-D is their lack of good advice regarding tyre pressures, which should be adjusted up accordingly when loading a bike close to its limits. In fact a very light rider may benefit from slightly lower pressures, just as a very heavy rider, even solo, should increase them above stock, before adding luggage and more pressure.
My Steering head bearings were shot at 11,000 miles on my 2017 Road Glide. It took me a while to figure out. It caused an uneasy weaving sensation and was enhanced in wet weather. It occurred at speeds greater than 30 MPH. Once replaced, the bike performed as it should....
