K&N filter backplate
Old Jul 10, 2007 | 05:43 PM
rickoshay45's Avatar
rickoshay45
Default K&N filter backplate
Looking at K&N it seems that you can just change the filter or use their kit with the replacement back plate.
Question: is the back plate really worth the money for a stage one upgrade?
Old Jul 10, 2007 | 05:51 PM
electra trike's Avatar
electra trike
Default RE: K&N filter backplate
If you plan on changing the mufflers then yes
Old Jul 10, 2007 | 06:04 PM
rickoshay45
I know it claims to increase the air flow, but what would I gain? 1HP or are there other factors?
I am looking at going with B&E Superflow Mufflers, a Fulsac true dual, and a PCIII.
My concern is heat and drivability, not pure performance. I also don't want to trade too muchfuel economy for performance.
I ride 80 miles a day to work and back, 60 on the Interstate and the rest in town. Usual in town speed about 40.
I also don't have a lot of money so I entend to do the mufflers and fulsac first and the K&N and PCIII later.
Old Jul 11, 2007 | 10:50 AM
UltraKla$$ic's Avatar
UltraKla$$ic
You might find THIS thread interesting. I know I did.
Old Jul 11, 2007 | 12:21 PM
LowriderFXRS's Avatar
LowriderFXRS
I put the K&N assy. on my FLHTC, but I went with the #3910 model which uses the 2 1/4" filter instead of the 1 5/8" used in the #3909. The air cleaner cover hangs out quite a bit farther than stock and gets in the way of my leg when going for the rear brake pedal. I'm going to replace the element with the narrower version and buy backa little leg room.
artz
Apr 22, 2011 07:12 PM
RK#1
Apr 13, 2008 12:46 AM
gdbro4
May 26, 2007 11:43 AM
nickdv9
Apr 7, 2007 02:54 AM
xlc06
Nov 8, 2006 01:02 PM
