My brothers 2004 ultra classic ,lost it's brake lights and turn signals along with some dash functions. The ignition light also stays on. Anyone know what FUSE this could be and where it is located? Where in Dawson City Yukon right now and will be a few more days before we get to a hd dealer in Fairbanks.
The fuse block is on the left side behind the removable panel in front of the saddle bag. I'm thinking you have more going on then blown fuses, If all what you say has gone wrong. Check for any codes that should be present. Look in the operators manual for code retrieval.
How do you go about getting codes on a 04? I have my fp3, but the plug ins are differant.
Ok, found out how to pull codes. Nothing changes on the odometer while holding the reset down and turning ignition on. No codes are coming up, but the red ignition light comes back on and stays on indicating a code is present.
Lets start with the fuses. Not sure why a light would stay on with a blown fuses, but maybe there is something that happens when it gets confused.
But if lights out, check fuses. Sometimes they look good, but are really blown. Stick a new one in, if not carrying a meter. They do make some small meters now a days, that are ok for some simple stuff.
I also lost my signal lights and brake lights on my 2006 Electra Glide ultra classic. All my lights are on (brake and signals) but when pressing foot brake and hand brake it will not work. Same for signal lights ,they are on but won't flash (front and rear) when pressing flasher hand controls.
