'04 FLHRCI Neck Bearing Zerk Fitting
Old Jul 11, 2007 | 09:22 AM
ScooterJammer's Avatar
ScooterJammer
Default '04 FLHRCI Neck Bearing Zerk Fitting
Hi, all...Can anyone tell me if this year ('04) Road King has a Neck Bearing Zerk fitting for greasing the Neck Bearings? I've looked and felt around, but so far, No-Joy.
ScooterJammer
Old Jul 11, 2007 | 09:28 AM
xxxflhrci's Avatar
xxxflhrci
Default RE: '04 FLHRCI Neck Bearing Zerk Fitting
Yes. It is on the left side of the bike. If you look behind the nacelle from the rear, left, you should see it.
Old Jul 11, 2007 | 10:55 AM
ScooterJammer
xxxflhrci...Thanks, I'll keep looking.
ScooterJammer
Old Jul 11, 2007 | 11:36 AM
petemac's Avatar
petemac
Is it the same for an '06 RK Classic?
Old Jul 11, 2007 | 12:17 PM
glide's Avatar
glide
All the RK's have the zerk. It's on the left side slightly forward where the frame starts to curve down low. Turn the bars to the right to see it.
Old Jul 11, 2007 | 12:39 PM
petemac's Avatar
petemac
Thanks. What kind of grease gun, and grease, do you need to get to service the neck bearings?
ORIGINAL: glide
Old Jul 11, 2007 | 01:17 PM
LowriderFXRS's Avatar
LowriderFXRS
I used Amsoilsynthetic chassis lube on mine. It's a super low-speed bearing so ANY good waterproof grease should work fine.
Old Jul 11, 2007 | 03:05 PM
glide's Avatar
glide
ORIGINAL: petemac
ORIGINAL: glide
While many swear by different brands for one reason or another, I like to use the HD brand special purpose grease #99857-97. Can't get any backlash from service if you have a problem down the road if you are using their product.
Old Jul 11, 2007 | 03:28 PM
petemac's Avatar
petemac
Thanks, that's the grease I was looking at. Since it's 14oz shouldright into a Sears grease gun.
ORIGINAL: glide
ORIGINAL: petemac
ORIGINAL: glide
Michael Mott
Jun 6, 2024 01:11 PM
Ron Jewell
Sep 5, 2018 09:55 PM
cjbmustang
May 28, 2011 06:38 PM
2008FLHP
Aug 30, 2008 09:27 PM
1potter1
Mar 10, 2006 01:22 AM
