2 oz makes a differenct
Old Jun 25, 2019 | 08:29 AM
barneyboy's Avatar
barneyboy
Originally Posted by 04FordHarleyF250
As I think about this more, I am sure it is just the newness of the friction plates as there isn't much clearance and the extra bit of oil takes that space up. I am sure after a couple of thousand miles it probably won't make a difference. Something that does bother me is why the engineers can't design for serviceability? 30 Oz of oil? C'mon, you couldn't make it an even 32 Oz? And the fellow with the 38 Oz, you make him buy a second quart to get 6 Oz of fluid. That's the kind of stuff that is just crazy. I wonder how many problems would be solved if things were designed with serviceability in mind. I realize it's beyond the scope of this forum.
If the engineers designed your primary to be refilled with exactly 32 ounces of fluid to ease serviceability, they would need to design the Canadian, European, and Latin American primaries to be refilled with 33.814 ounces of fluid. Oil is sold in 1 liter bottles in those countries.
Old Jun 25, 2019 | 08:34 AM
strych9's Avatar
strych9
Most places throw a quart in each cavity (trans and primary) and call it a day. That's why it's best to do it yourself if you expect precision. Does it make much difference? No.
Old Jun 25, 2019 | 08:40 AM
04FordHarleyF250's Avatar
04FordHarleyF250
Yes, that's true with the metric liters. This is the USA, we do inches, feet, yards, miles, ounces, pints, quarts, pounds, etc... That counting by tens thing is lame. Besides oil is sold by the quart here.
Old Jun 25, 2019 | 09:08 AM
Bone Doc's Avatar
Bone Doc
Originally Posted by AussieDog
My primary takes 38 oz on a wet change. The 1st time I did it myself I carefully and slowly measured what came out when I drained it - 33 oz. I put 33 back in, it just didn't feel right. I ended up adding 4 oz -- a 1/4 cup! It then seemed fine. Every since when I change I go back with 38 oz and all is fine. That's all I know for my bike.
For accuracy sake; 4 oz is 1/2 cup
Old Jun 25, 2019 | 09:17 AM
btsom's Avatar
btsom
It still amazes me the number of people who put in a fixed amount of oil and then BELIEVE the level is correct. The amount of oil actually needed depends on the amount drained out. If a few ounces are left behind, then the FIXED amount of replacement oil will overfill the reservoir. As stated by most, it is not critical, but the factory supplies DIP STICKS for a reason and a level reference for the primary. Some people take great pains for a thorough drain, others just let the fluid run out until it stops and reinstall the plug. Each technique requires a different amount of replacement lube to achieve the SPECIFIED level.
Old Jun 25, 2019 | 09:40 AM
Cygnusx51's Avatar
Cygnusx51
^ Correct. I’m already looking into the hole to replace the primary fluid so I also just pour it in until it’s at the correct level. It’s a simple fluid change, and I agree, some people just have to make it more difficult than it really is.
Old Jun 25, 2019 | 09:51 AM
barneyboy's Avatar
barneyboy
And your F250 has what engine in it?
Old Jun 25, 2019 | 02:43 PM
K Melancon's Avatar
K Melancon
My 19 calls for 28 oz. in primary and 30 oz. in the trans. Yes different than my last bike of same model. But always check that it is to the full mark
Old Jun 25, 2019 | 02:54 PM
Dynamick's Avatar
Dynamick
Not always true, at least in Canada.
For example, the oil I bought yesterday for my D.D. oil change came in 5 US qt (4.73 liter) and 1 US qt (.948 liter) containers.
And it's the same situation here with many motorcycle-specific lubricants as well.
Old Jun 25, 2019 | 03:56 PM
04FordHarleyF250
I have a question for those outside the USA. When going to the HD dealer outside of the USA, is oil sold by the liter or by the quart?
