I need suspension advice
Old Jul 12, 2019 | 12:28 PM
bdtaylor1979's Avatar
bdtaylor1979
I went from the stock air shocks on my 2014 ultra limited to some stock premium adjustable shocks off of a 2018 ultra limited. Night and day difference in my opinion. Better, smoother and more firm ride. I'm about 200lbs and my girlfriend is 120lbs. I wish I would have swapped out the shocks sooner. I paid $175 shipped from someone here on the forum. The ones on the 2018 ultra limited are 13 inch just like the stock air shocks on the 2014 ultra limited.
Old Jul 13, 2019 | 04:37 AM
SNDSLGR's Avatar
SNDSLGR
13-1/4" ohlins on rear and ledgend axeo front on my '15 UL. You won't regret it.
Old Jul 13, 2019 | 09:14 PM
thefirstbigone's Avatar
thefirstbigone
I made a decision on suspension after some education from my H-D dealer. I ended up with Legend Revo-As on the rear. My dealer highly recommended them and even knocked about $100 off the price. They did warn me I would be back for parts to do the forks.
These things are are pricey but pretty nice. The install and setup was about as easy as it can get. I didn’t realize how ineffective the air shocks were at smoothing out my ride. I put about 100 miles on these today on some pretty rough streets at slow speeds and some asphalt roads with a lot of patchwork at highway speeds along with several rail road tracks. While it’s not like floating on air it is very much improved. The front wheel is definitely rougher riding than the rear. I’m not sure if tinkering with the spring and rebound adjustments will make it any better or not so I think I’ll just drive it for now and get some miles on them.
While led these were pricey I like what I’ve seen so far. I have no regrets and would buy these again. The question now is if I’ll do the fronts this winter or sooner. Thanks to all that offered input here. I love this site.
Old Jul 14, 2019 | 05:22 AM
grbrown's Avatar
grbrown
Talking
Your experience is one that will be familiar to those of us who have done a similar suspension upgrade! If your ride at present is acceptable, wait until you have around 500 miles up before making any fine adjustments, as your new shocks are likely to bed in. Then you can shop for a suitable fork upgrade - you are in good company!
Old Jul 14, 2019 | 05:34 AM
todd-67's Avatar
todd-67
I have run Ohlin's, Pro Actions, Bitubo, HD air shocks and the HD premium shocks. I currently have Pro Actions on my glide and Bitubo's on my road king. Pro Actions and Ohlins are about the same with the nod going to Pro Action for a better build quality and a slightly better ride. They are also made in America like the Revo's which I have not tried. Both the Ohlins and the Pro Actions seem better suited for heavier 2-Up loads. The Bitubo's were a surprise as to how well they ended up performing. I have not had them loaded down for a trip yet but for the riding that I have done with them both solo and 2-up they perform night and day against the stock stuff. The 13" HD coil overs are definitely an improvement over the stock air shocks and are the easiest to adjust for large loading changes but they still are lacking. For the right price though they are an option.
Old Jul 18, 2019 | 11:08 PM
OZARKTOAD's Avatar
OZARKTOAD
What size pro actions are you running? I’ve got progressive mono tube in the front and 13” premium HD’s In the back. Im wanting to go with 12” but not sacrifice ride. Leaning towards 944 touring... would like to know how pro action 12” ride?
Old Jul 24, 2019 | 11:23 AM
JonnyVegas's Avatar
JonnyVegas
speaking to the HD premium shocks, can anyone recommend how many turns for 18 RGS shocks?
they ride stiff ! im sure its a matter of adjustment
Old Jul 24, 2019 | 03:06 PM
big- mike's Avatar
big- mike
I put a set of hd premiums on my 2010 ultra off of a 2018 ultra I got the set on 3 or 4 clicks and I’m 250lbs much better than the air shocks. Let’s admit it they are never gonna ride like a Cadillac and I can buy a whole lot of stuff for the difference in cost between them and the Ohlins
Old Jul 24, 2019 | 04:36 PM
Hammz's Avatar
Hammz
Your settings for the H-D Hand Adjustable 13" shocks are close to mine. I go 265, wife just under 200. Solo I ran 2 turns (4 clicks) from full off & 4 or 5 turns (8-10 clicks). Got about 28kmi on them & they were done (needed a rebuild). At that point, I was ready to upgrade. Ohlins HD159's custom built for me.
When recommending shocks, there's a lot more than just brand name to consider:
  1. emulsion (nitrogen & oil in same chamber)
  2. dual chamber (nitrogen in one chamber, oil in another chamber)
  3. pre-load adjustable
  4. rebound adjustable
  5. length adjustable
  6. damping adjustable
Ohlins sells shocks in various combinations of all these listed features. Other brands, in general, don't sell shocks with as many different feature sets. For most street riding, an emulsion shock should be adequate, especially when if it include both pre-load & rebound adjustments. Progressive uses a proprietary self-adjusting valve assembly, so you won't find rebound or damping adjustability on their products.
My point here is be careful comparing brand only w/o accounting for matching features in the comparison.
Old Jul 24, 2019 | 05:50 PM
todd-67's Avatar
todd-67
Mine are the 13". I would exhaust all options first before going to shorter shocks.
