I need suspension advice
Old Jul 11, 2019 | 10:48 PM
thefirstbigone's Avatar
thefirstbigone
Default I need suspension advice
I have a 2014 Ultra Limited and I’m giving up on the air shocks. It’s been a long process of trying to make them work and I’m ready to upgrade. My rider weight with gear stays at a constant 350 lbs. there is so much information out there my head is spinning. I’m willing to spend a reasonable amount of money for a decent ride buy I don’t have endless funds for this project. My requirements for this project are a good ride of course, durability, able to work with 350 lbs of riders and gear, retain stock riding height, and cost of $1,000 or less. I would also like something that can be paired with a front suspension in the future. I would also like something that can be at my doorstep within 2 weeks.
Spoke with local H-D dealer today about their aftermarket offerings and they bragged up the factory air shocks. That’s why I use a dealer 100 miles away. They recommended Legend Revos. They claimed they were a step up from progressive 944s.
I know there are hundreds of post on this but most are old and several seem to get off track quickly. I could use some good advice.
Old Jul 12, 2019 | 01:51 AM
99Birdman's Avatar
99Birdman
From my experience, there are several levels of upgrades you can go for (this is one area where you kind of get what you pay for).
Most expensive: If you ride a lot and can appreciate really good suspension, Ohlins, Legends, and a few other top tier shocks will make you very happy.
Middle road: Progressive makes some very good shocks but not nearly as good as the above
Best bang for the buck: Harley's Premium Adjustable shocks work pretty well at your weight numbers. Not nearly as goodl as the above but, you can get them on the forum (or eBay) for a fraction of what you'll spend for premium shocks and if you don't like them, you can sell them and go another route. Very many people are very happy with this option.
My own preference is Ohlins but, I have many friends who can't tell the difference.
Old Jul 12, 2019 | 04:47 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
There's an interesting thread or two on Bitubu, who makes interesting shocks and a fork kit. It's one of the few that genuinely has my interest. No personal experience.
https://www.hdforums.com/forum/touri...ck-review.html
Old Jul 12, 2019 | 09:09 AM
Zedbra's Avatar
Zedbra
Everyone has their own preference. I chose Pro-Action shocks and have been very happy with their performance, now with 6k on them. I chose these over Ohlins due to the body's tight threads on the Ohlins becoming gummed up with dirt easy - the Pro actions seemed a little more well designed. Again, just another opinion. Ohlin does make great suspensions components. From what I have read here, the Legends seem to be rather stiff riding
Old Jul 12, 2019 | 09:13 AM
sanman4ever's Avatar
sanman4ever
Make sure you get a 13" shock
Old Jul 12, 2019 | 09:24 AM
grbrown's Avatar
grbrown
Wink
There are two ways of looking at this challenge! One is to do as I did and try some of the 'promising' but less expensive products - and find them less than satisfactory, which can consume both time and money. Two, cut out all the 'promising' stuff and go straight to the top-rated brands, of which there are very few. That will give quicker results and you are far more likely to find nirvana than option One.
Having upgraded your shocks, do be aware that your forks will naturally follow, as good shocks will show up how poor the stock forks are. At the time I made my choice the selection was simple, as Ohlins stood on the top of the pile. You can always swap out the shocks when changing bike (or bike brand), although doing that with forks internals is not so simple.
Old Jul 12, 2019 | 10:08 AM
intrepidxc's Avatar
intrepidxc
I went with Progressive 944s simply because I wanted to lower the back end by 1 inch and keep the full shock stroke. I notice a slight difference between the Progressives and other FLTRUs setup with Ohlins or Legends, but not enough to give up the lowering I wanted (without using a lowering block).
Just something else to consider.
Old Jul 12, 2019 | 10:17 AM
elPrez's Avatar
elPrez
I tried Progressive over stock air shocks and they were OK. Had for several years. Last year I went with Ohlins and can't believe how great they are. Wish I got them from the beginning. Just north of $800
Old Jul 12, 2019 | 10:36 AM
n of 1's Avatar
n of 1
If at all possible try and ride something with the different shocks. This may prove impossible but perhaps the dealer or a bike rally etc would provide an option.
Otherwise given your requirements I'd jump in at the top with legends or ohlins from what I've read. Keep in mind I've never ridden these, this is only a "reading" recommendation.
I put the bitubo 13" shocks on my bike, and I'm not so sure it was worth it. I wasn't personally dissatisfied with stock but want my passenger to feel better on rides (she's not happy w/ the stock set up), and I wondered if I just didn't know how comfortable it could be. Since I had a bit of money available I figured why not. I've only ridden a hundred miles or so and its different but not life changing by any means. FWIW my personal load is about 200. I purchased from bellissimoto and wouldn't recommend them for you. The price/product was o.k. but it took over month for them to arrive.
Good luck in your search.
Old Jul 12, 2019 | 10:50 AM
grbrown's Avatar
grbrown
Cool
Originally Posted by n of 1
……. I'd jump in at the top with legends or ohlins from what I've read. Keep in mind I've never ridden these, this is only a "reading" recommendation.
That's how many of us have progressed! I bought my Ohlins shocks back in 2008, when the options were not as many as today and it required a leap of faith. That comment still applies today, but many more of us are riding around on them now.
Be bold and look forward to a wonderful ride!
