Reverse Options
Like any slow manuevers, the clutch friction zone will be your friend and be very gentle with the front brake. You will be going very slow and the front brake will take you down very quickly if you grab it to hard.
Try not to turn the HB's too far in either direction until you get used to backing it up. Like when just pushing the bike backwards with your legs, if you turn the HB's too far the bike can get very heavy.
When backing straight, you will able to use your mirrors but not when turning. So make sure you know where the bike is going. You will have to stop in order to look over your shoulder. When backing up more than a few yards, I will stop often to make sure I'm not heading into something or heading off the paving.
While my lady was out of state for a few weeks I found I prefered to back up my 40 foot driveway when returning to park under my carport. That makes it much more pleasant to pull out easily when leaving. But when there is two cars and two bike under the carport I'm forced to pull in forward when returning and back out with a big tight curve in order to orientate the bike to face out toward the road. Not a problem, just a bigger tighter curve then when I would back up the drive.
Probably just me, but when curving while backing I prefer to turn my HB's to the right. That may be because I've got used to doing that as I park on the left side of the carport and must turn CCW to get out. It is lucky that my driveway is 21 feet wide so I don't have to back out onto the road.
Just like when you back a bike up using leg power, when pulling up to park set yourself up as best as possible so you can back up with as little curve needed as possible.
Hope some of this helps
Edit: Just one more thing...be patient. The process of putting the bike in neautral, pressing and holding the button for a few seconds and than putting into first gear takes a a liitile bit of time. Take your time and don't be rushed. And, dont forget to take it out of reverse before shutting the bike down.
I couldn't agree more, (I have their suspension).
Ken
Beware of going too fast in reverse. It’s awkward. Yes, some get very used to it. I am not one of them. I can certainly do it just fine, but I pay attention and think throughout.
with the main transmission in neutral, parasitic drag will have the main shaft spinning. So engagement of the reverse is with a gear grinding crash. That’s why I do it with the main transmission in gear, then shift to neutral and back up. You can also simply engage reverse with the engine off, pull the clutch, and start the engine.
the reverse shift lever can be awkward to actuate, depending on how you’re situated. Crossed up on a slope for example. There have been s few times where I’ve simply shut the bike down so I can carefully disengage, or engage, reverse without falling over.
tight backwards turns are awkward. Especially tight left backwards turns. None the less, I do one every time I back out of my shed. On a cross slope no less.
So mostly, go slow, go gently, and you’ll be fine.
