Upgrading....which way to go??
Old Jul 12, 2007 | 07:14 AM
trex_47e's Avatar
trex_47e
Default Upgrading....which way to go??
I'm going to be upgrading Street Glides this week to a 2007. The questions is which engine upgrade to put in it. I'm lookingfor the most bang for the buck. Should I put in the 110in kit, or just go with a 103in? Opinions?
Old Jul 12, 2007 | 07:17 AM
DI75's Avatar
DI75
Default RE: Upgrading....which way to go??
103 stroked!! 115hp/115tq!!!!!!!!!!!![8D]
Old Jul 12, 2007 | 07:24 AM
trex_47e's Avatar
trex_47e
ORIGINAL: DI75
DI75 I love your wheels.
Old Jul 12, 2007 | 08:22 AM
nidan's Avatar
nidan
I just did the 103 stage II ( SE 255 cams)/SERT with the 4"Street performance slip -ons, the Cat ones don't perform as well as the one I have . It is a s far as you can go under warranty with the 103. I can't see the expense of going to the 110" . I've ridden the 110 and didn't think it had noticeably more power. My Stage IV 95" WG3 would outperform both. The new 103 build power very smoothly and comes on the cam at 3000 . It doesn't slam you back , but has a nice progressive gain. I've only got 350 miles on the build but I'm happy with it until warranty runs out. Then I'll at least add heads.
Old Jul 12, 2007 | 08:41 AM
Rattle Can's Avatar
Rattle Can
It's my understanding that you need to split the cases for the 110 build. A lot more work and expense for what you would get out of it.
Old Jul 12, 2007 | 08:53 AM
mmollo's Avatar
mmollo
ORIGINAL: nidan
I just did the 103 stage II ( SE 255 cams)/SERT with the 4" Street performance slip -ons, the Cat ones don't perform as well as the one I have . It is a s far as you can go under warranty with the 103. I can't see the expense of going to the 110" . I've ridden the 110 and didn't think it had noticeably more power. My Stage IV 95" WG3 would outperform both. The new 103 build power very smoothly and comes on the cam at 3000 . It doesn't slam you back , but has a nice progressive gain. I've only got 350 miles on the build but I'm happy with it until warranty runs out. Then I'll at least add heads.
I did the same at delivery. Nidan I agree, it won't slam you back, but you know it's there. Heads will be next after warranty.
Old Jul 12, 2007 | 02:48 PM
trex_47e's Avatar
trex_47e
Thanks for the info. I decided on a 103 kit with a 260 cam, upgraded pistons and head. Also going to install Bassani true dual exhaust, with Thunder Max tuner. I will let you know how the dyno turns out.
hamdizle
Exhaust System Topics
Jul 27, 2011 04:33 PM
NATESBPD
Nov 2, 2008 09:51 PM
Pirate Boy
18
Oct 29, 2008 02:48 PM
pelliott6
May 23, 2008 12:49 PM
Bluesman69
May 19, 2007 09:37 PM
