Accessory Wiring Harness ???
Old Jul 21, 2019 | 07:16 PM
dcfatboy's Avatar
dcfatboy
Old Jul 21, 2019 | 07:24 PM
dcfatboy's Avatar
dcfatboy
Did your Cool Flow Fan installation include the RH switch pack?
Old Jul 21, 2019 | 09:15 PM
Vernal's Avatar
Vernal
Originally Posted by TOHOG
This plug is used for the Cool Flow Fan but it has a Seal Pin in one slot. Could I remove that pin and insert the fused power wire terminal in there?
OK, but when I test for power on the two ACC connectors that came with the last harness (for RH dash switches) I get no power to them. I do see where first extra harness is fused to the battery and connected to a plug that sends power to the Cool Flow Fan and other ACC outlets steming from that harness but on the new harness there is ACC1 and ACC2, neither are powered.
Maybe I do need the second fused wire for this harness just like the one for the first one? Does that make sense?
TIA
That connector with the seal pin looks to be 325.
The fused wire to pin 3 would be used if you have something you want powered even with ignition off, it will not be controlled by the ignition switch like the V/BE.
Are you checking for power wit ignition on?
Old Jul 25, 2019 | 08:06 AM
TOHOG's Avatar
TOHOG
Thanks again to all! I decided to use the open position on the MX150 which was used for the FAN. Show in photo. When I connected that to the plug and the pos terminal of the battery it gave me power to ACC1 and ACC2 wiring which are activated by switches on RH dash I installed.
I believe I have what I want now. Easy plug and play for fog lights, additional lighting, horns, love jugs.
Old Jul 25, 2019 | 11:26 AM
Vernal's Avatar
Vernal
Is that circuit controlled by the ignition switch or always on? If on buy one of these, if your like me you'll forget to turn things off. https://shop.antigravitybatteries.co.../micro-starts/
Glad you got it figured out..
PTYRider
Mar 29, 2019 07:34 AM
wheath
Apr 11, 2018 08:16 AM
DC2009EGUC
2014-2024 Touring Models
Jan 23, 2015 06:49 AM
ROLLNTIGER
Audio Systems
May 15, 2014 02:33 PM
Shark Ride
Aug 26, 2011 08:56 AM
