I did a search and couldn't find the answer.
I have a 2014 ultra limited and have been thinking about changing the exhaust.
I'm curious what year touring header pipes will work?
I found a set of true duals and rinehart mufflers from a 2012 road glide and wondering if they will fit my 2014 ultra limited?
Generally 2010 to 2016 touring exhaust interchange. I believe 09 has a different location for O2 sensors.
What he said. 2009 are carless, and have o2 sensors near the port, 10 and later have cats and sensors lower down. Aftermarket may have provisions for both styles but depends on mfg.
Hopefully the wires for the o2 sensors are long enough. I'm looking at getting some used ones that came off of a 2012 road glide with rinehart slip ons and true duals.
they might have 2 sets of O2 sensor holes. the ones by the exhaust port are smaller diameter an I believe for wide band O2 sensors for aftermarket tuners an down by the trans is the where the stock sensors go. They sell plugs for the unused ports.
