Its probably going to take a little while as the 10's have 12mm O2 sensors and 09 and older bikes had 18mm sensors. After market companies will need some time to retool a little for the O2 bungs.
Thanks ya'll. Just found out today that it won't fit my '09 without changing the 02's which are located in a different spot on the pipe, which means new sensors AND some wiring work. That's too much work and money to justify piecing a system together to save cash........ D*MN!T!
Some more harley bullshit!!!!! I can see a change maybe 3 years from now,but not even a year later!!!WTF now how much more $$ the pipe makers are going to jack up the price for relocating the bungs on the same 09' pipes by labeling them "Brand New 2010" exhaust sys???
BTW do the 2010 SEFLHX have a falsie on the left side now,or is it the same as the 09' touring bikes????
I have a question on this subject on the '10 RG's.. I was wondering IF there was dual mounting hardware on the left side under the bag or not.. I guess I should go out and check one, but for when dual pipes are available do we need some more $$$ for mounting hardware or what??
Supertrapp is offering a slipon for the 2010 2 into 1.
50 state legal, quiet . . . but can add discs.
Originally Posted by Unome
Had Granite Mountain H-D - Conyers, GA - roll out a 2010 SG which had the new SE pipe on it so I could hear the sound.
I swear it looks just like a SuperTrapp.
Sounded pretty good. If I had helmet with me, I would have asked to test ride. I'm thinking about going with SuperTrapp 2-1 on our 2007 EGC.
My dealer has a 2010 sitting on the floor with a Screamin' Eagle pipe that is actually a Supertrapp pipe. Take out the discs for more voulume if you want (they say). It did sound like a HOt Rod.
its not a complete change to the exhaust system. they still have the 2-1-2, but are also offering a 2-1. i bet if you really wanted to, you could change out the 2-1 with the 2-1-2 (at your expense of course).
