Need help
Old Jul 29, 2019 | 05:03 PM
Brandon Floyd's Avatar
Brandon Floyd
Stage I
Default Need help
I have a 2006 street glide. Here the last few days it seems like it has bad gas or water in the tank but I eleminated that problem. When I run it and let off throttle it pops and backfires. When I'm at low speeds I have to keep on throttle to keep running. What are you guys thoughts on this? Maybe fuel pump or something.
Old Jul 29, 2019 | 07:52 PM
470004's Avatar
470004
Welcome to the forum.
Old Jul 29, 2019 | 08:15 PM
Mr. Mike's Avatar
Mr. Mike
Brandon,
Do you have a FSM? Good to have if you don’t.
Have you checked for diagnostic error codes?
Search these items listed below and check (before having it towed to your shop of choice);
Pin holes in the in-tank fuel lines
Throttle Position Sensor
Dirty Idle Air Control
Dirty Speed Sensor
Old Jul 30, 2019 | 01:01 PM
hattitude's Avatar
hattitude
Good ideas above, but I'm wondering, do you have a carb or EFI.....?
Old Jul 30, 2019 | 04:03 PM
Mr. Mike's Avatar
Mr. Mike
😖...yep, you got me on that one.
HEY, BRANDON.................
Old Jul 30, 2019 | 07:33 PM
steelerdude1's Avatar
steelerdude1
Welcome from PA
If injected, try cleaning the IAC. It’s at the 12 o’clock position on the throttle body. Generously spray it with some carb cleaner.
Old Jul 30, 2019 | 10:47 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Try spraying the IAC with Mass Airflow Sensor Cleaner not carb cleaner. Carb cleaner will leave a residue after it dries and jack up the IAC even further. Mass Airflow Sensor Cleaner doesn't leave any residue after it dries.
erock555
May 5, 2017 06:03 PM
ez__rider
Carburetor Related
Mar 20, 2015 04:10 PM
jaystay42
Exhaust System Topics
Aug 6, 2011 08:10 PM
BillyJoe44
May 7, 2011 06:14 AM
bob1378
Jul 28, 2010 08:00 AM
