Tuning issue
Old Aug 1, 2019 | 07:40 AM
Fatti's Avatar
Fatti
Stage II
Default Tuning issue
I have a 2013 FLHP , was running a Vance and Hines FP3 tuner entered auto tune for my new Bassani true duels 551 cams SNS Stelth intake and something went wrong in autotune got check engine light , The bike ran like crap after that . I had it dynode with a PCV Dynojet . The bike runs great now except for cold start idle peaks and valleys in first gear feels like I’m trying to get out of second gear have to work the clutch a little bit ,
Old Aug 1, 2019 | 09:56 AM
grbrown's Avatar
grbrown
Hi from the UK and welcome to HDF. If you had your bike tuned on a dyno, I suggest you contact the tuning shop and get them to make suitable adjustments, to correct that, which they should be able to do pdq.
Old Aug 1, 2019 | 07:28 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Did you load the basic FP3 map for your mods prior to doing the auto-tune?
Old Aug 2, 2019 | 09:57 AM
Fatti's Avatar
Fatti
Stage II
Default Yes
yes, however FP3 didn’t have my exact components , FP3 is now gone and I’m running Pcv , my dyno guy says for some reason had trouble adding fuel below 1,000 RPMs but it idles fine
Old Sep 17, 2019 | 12:41 PM
summitgmc's Avatar
summitgmc
Did you try reloading the stock map, the one it saves in slot 1, before you removed the FP3 ?
ejwmiller
Jun 5, 2015 01:53 PM
powerman1972
Aug 20, 2014 01:21 PM
Wingsfan
Apr 7, 2014 08:30 AM
foxman
Apr 16, 2013 10:49 PM
Puttnutt24
Jun 15, 2009 01:13 PM
