King tour pack without backrest?
Old Aug 9, 2019 | 07:37 PM
Jersey Drew's Avatar
Jersey Drew
Default King tour pack without backrest?
Are there holes pre-drilled or can you run the king tour pack without the backrest?
Old Aug 9, 2019 | 08:57 PM
GalvTexGuy's Avatar
GalvTexGuy
Another thread? Okay, so watch this video starting at 5:53. He does not drill any holes. Buy some plugs for the holes. Problem solved!
Old Aug 9, 2019 | 09:58 PM
Jersey Drew
https://youtu.be/Mnfyer4l89U
Yes sorry. I thought i would get better answers here. I appreciate the vid, i will watch it now.
Old Aug 11, 2019 | 08:34 AM
Zerk's Avatar
Zerk
What is the question? I agree touring section is better place. I ignored thread, cause I thought it was a guy asking do you think my bike would still be pretty if I didn't have a backrest on the trunk. To which I say, it is nice to lean stuff on, when you have stuff strapped to back seat.
Old Aug 11, 2019 | 11:13 AM
JonW's Avatar
JonW
I thought the OP asked a straightforward question. It's hard to tell in the video if the holes for the backrest were pre-drilled or not. If so, go to the hardware store and find some rubber plugs for them. Most likely in the automotive section. Also check out bumperplugs.com.
Old Aug 11, 2019 | 01:56 PM
Jersey Drew
yes i was being impatient and started this thread here and i had already had one going in the general chat forum. from the vid and others who have replied i am pretty confident the tourpack has the backrest holes predrilled. i would oly use the TP for long hauls and i do not ride with a passenger so i was hoping to not have to buy a $250 backrest when all i need is the box itself.
Old Aug 11, 2019 | 06:47 PM
Slowpoke62's Avatar
Slowpoke62
Unless you just have to have a Harley (manufactured) one, there are many on e-bay and amazon that you can buy with no holes. I am also a solo rider and I recently got a solo tour pack mount(not Harley) that I am going to get a King pack (also not Harley) and mount it so it can also be a backrest. I am going to use the razor pack backrest on it. By the time I'm done, I will have less than 500 in the whole thing. Try doing that with Harley parts.
Old Aug 12, 2019 | 01:16 PM
Hammerdown77's Avatar
Hammerdown77
Let us know how that goes, because I was hoping to do the same thing, but then I've seen several other threads where folks say the pack does not sit far enough forward to use as a back rest without making an adapter bracket or something similar.
Old Aug 12, 2019 | 02:21 PM
Ssitruc's Avatar
Ssitruc
I think it depends on arm length, height, and such... It did not work for me so I made an adapter plate of sorts. Made them using 2 12" X 1/2" X 2-1/2" aluminum bar stock. Painted them black and they disappear. See pic below... With it I can slide my chopped another 2 or 2-1/2 inches forward. Also had the back rest re-worked and cut a curve in it, and added 2" of padding to the flap for lower back support.
Side benefit of the adapter plates/rails I made... I can open saddlebags w/o having to watch out for the latches as they pass under the tourpak and I was able to put the quick-connect locks on the rack (just modified one of the keys).
Old Aug 12, 2019 | 03:08 PM
tcatnat's Avatar
tcatnat
Take a look at this thread. I have been considering something like this also...
https://www.hdforums.com/forum/touri...-backrest.html
