Floorboard extensions.....
Old Aug 30, 2019 | 12:25 PM
blazzent45's Avatar
blazzent45
Originally Posted by Hammerdown77
There are two methods to move the boards outward. One is to put spacers between the brackets and the frame (for God's sake don't use hardware store washers, get real spacers), the other is to use extenders between the bracket and the board at the hinge.
The first method increases the risk that you will touch down a fixed part, i.e. the brackets. Touch them down too hard and you'll lever the wheels off the pavement. This can be an unpleasant and potentially painful experience.
The second method increases the likelihood that you will scrape the boards, but the boards hinge up freely, so this is not an issue.
Personally I wouldn't go more than 3/4" on a spacer fit between the frame and the brackets. Anything more than that (some go out to 1.5") is just asking for a potentially catastrophic surprise.
That's a good point, I'll have to check into it.
Old Aug 30, 2019 | 02:56 PM
hardheaded's Avatar
hardheaded
I bought mine from DK customs and they are great. I've had many friends buy them after sitting on my bike and seeing what a differance they make. I sure wish i would have found them sooner.
Old Aug 30, 2019 | 03:14 PM
UltraDuff's Avatar
UltraDuff
Default Floorboard Extensions
+1 for DK Customs. It feels a lot nicer not having to hug the tank. While you're at it, I also did the DK Customs extended brake pedal. Again, soooo much nicer angle for the pedal.
Duff
Old Aug 30, 2019 | 04:19 PM
blazzent45's Avatar
blazzent45
Originally Posted by nobodyknowsme
Not out, but more overall movement back and forth, I have Cyclesmiths Banana Boards on both bikes. Here they are on my RGS. They are the ultimate comfort mod IMO.
Man I could almost take a nap on those board, looks like a ton of room for the long haul. NICE
Old Aug 30, 2019 | 04:29 PM
Pothole914's Avatar
Pothole914
I also used DK Custom's extensions on my 19 SGS. Moved the boards out 1". Made big difference.
Old Aug 30, 2019 | 11:15 PM
Ragtop's Avatar
Ragtop
I did the SOOS 3/4" kit. Not sure if he is still a member here or not, worked out good for me
Old Aug 31, 2019 | 03:54 AM
RFG7680's Avatar
RFG7680
I use the Kuryakyn 1" forward and 1" out brackets that mount between the board and the mount. Been running them on every bike since 2010.
Old Jan 4, 2020 | 10:15 PM
Malinois's Avatar
Malinois
Stage III
Default Floorboard extenders
Has anyone put 1 inch out and 1 inch forward on a Road Glide Limited? I recently traded my 16 Road Glide Special for a 2020 RG Limited and unsure if I can do the same with the lower fairings almost looks as if the boards will end up in the fairings.
Old Jan 4, 2020 | 10:19 PM
6113_'s Avatar
6113_
your wheels don't match?
cool floorboards though,
Old Jan 5, 2020 | 12:59 AM
Kazu Hiro's Avatar
Kazu Hiro
DKCustoms kit. Fast n easy to install. About $55
