Floorboard extensions.....
Old Aug 30, 2019 | 08:08 AM
blazzent45's Avatar
blazzent45
Default Floorboard extensions.....
I want to push my RK floorboards out. Post some pics, let me know how you did it and or witch kit you used as well as how you like the Mod......
Old Aug 30, 2019 | 08:15 AM
DeputyDawg's Avatar
DeputyDawg
I went to Home Depot and bought longer Grade 8 bolts and washers to use as shims on the bolts.
Old Aug 30, 2019 | 08:21 AM
Uncle Larry's Avatar
Uncle Larry
There are several manufacturers of floorboard extensions / fixes .... Some move out a little, some out a little bit further, some that move them forward and some that move them forward and out ( Kuryakyn comes to mine ) I have the 1" out ( if I remember correctly ) and they're comfortable ... I'm 6'2"
https://www.google.com/search?q=harl...hrome&ie=UTF-8
Old Aug 30, 2019 | 08:26 AM
MyFavRk's Avatar
MyFavRk
I used the Kuryakyn floorboard spacer kit , part # 7509 . These will bring your boards out another 3/4" . I actually ride with my heals on the boards and the tip of my boots on the road pegs . I find it quite comfortable ..
Old Aug 30, 2019 | 09:10 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Washers for me too.
Old Aug 30, 2019 | 09:34 AM
blazzent45's Avatar
blazzent45
I was thinking of kicking them out as much as 1 1/4 just don't know how it would look.. I got wide feet. Lol
Old Aug 30, 2019 | 11:45 AM
Hammerdown77's Avatar
Hammerdown77
There are two methods to move the boards outward. One is to put spacers between the brackets and the frame (for God's sake don't use hardware store washers, get real spacers), the other is to use extenders between the bracket and the board at the hinge.
The first method increases the risk that you will touch down a fixed part, i.e. the brackets. Touch them down too hard and you'll lever the wheels off the pavement. This can be an unpleasant and potentially painful experience.
The second method increases the likelihood that you will scrape the boards, but the boards hinge up freely, so this is not an issue.
Personally I wouldn't go more than 3/4" on a spacer fit between the frame and the brackets. Anything more than that (some go out to 1.5") is just asking for a potentially catastrophic surprise.
Old Aug 30, 2019 | 11:47 AM
04FordHarleyF250's Avatar
04FordHarleyF250
I went with tall boy brackets on my Electra Glide -> https://www.tallboyscycles.com/ and did the Kuryakyn 3/4" inch spacers as well. Additionally did the extended brake pedal arm and shifter arm. I used to ride a fat bob and got used to forward controls. This set up puts me near that riding position and no need for highway pegs,. Another solution that I saw on another bike is peg boards -> https://www.pegboards.com/ . They are pricey but are probably a better solution. Does any one have peg boards and want to comment on them?
Old Aug 30, 2019 | 11:53 AM
nobodyknowsme's Avatar
nobodyknowsme
Not out, but more overall movement back and forth, I have Cyclesmiths Banana Boards on both bikes. Here they are on my RGS. They are the ultimate comfort mod IMO.
Old Aug 30, 2019 | 12:24 PM
blazzent45's Avatar
blazzent45
See when I sit on the bike my feet hang off the outer edge of both boards, I"m bow-legged and I got big feet..... Really I'm not used to this big ol hunk of iron between my legs, flipping Honda's.
