Ventilator air cleaner
Old Sep 2, 2019 | 12:25 PM
danny54's Avatar
danny54
Default Ventilator air cleaner
My 2016 SGS came with the SE ventilator air cleaner, The filter looks white. Are these washable or are they standand with KN filters, Thanks Dan
Old Sep 2, 2019 | 12:52 PM
LQQK_OUT's Avatar
LQQK_OUT
https://www.harley-davidson.com/stor...ir-cleaner-kit
https://serviceinfo.harley-davidson....2?locale=en_US
This is a dry air filter. Do not apply oil to the filter element.
When servicing the air cleaner, apply Loctite 243 - Blue to the threads of all fasteners.
1. See Figure 3. Remove the air cleaner cover (8) and inspect the filter element (7) every 8,000 km (5000 mi), or more often under dusty conditions.
2. Clean the filter element (see Figure 2 ):
Remove and wash the element by immersing it, on edge, in a shallow pan containing enough Air Cleaner/Degreaser (1) to cover no more than three-quarters of the depth of the filter pleats (2), about 9.5 mm (0.375 in). Do not allow dirty solution to get inside the element. Carefully "roll" the element in the solution around its perimeter (3) until the entire outer surface of the filter pleats has been soaked.
Remove the filter element from the cleaner/degreaser. Allow five minutes for the cleaner to dissolve the dirt.
From the inside out, rinse the element with cold water. Shake off excess water. Allow the element to air dry. Do not dry with compressed air.
3. Install air cleaner filter and cover.
Old Sep 2, 2019 | 01:02 PM
danny54's Avatar
danny54
Great info, Thankyou!
HardLuck71
Nov 29, 2024 02:03 PM
4Evr_Cruzn
Aug 29, 2019 07:34 PM
fnunez
General Topics/Tech Tips
11
Jan 26, 2016 11:24 PM
dblcruzin
Apr 14, 2009 11:54 AM
GMan06883
Mar 22, 2007 11:44 PM
