Check Engine light
Old Sep 4, 2019 | 04:39 AM
buddy67's Avatar
buddy67
Default Check Engine light
Have a 15SG and over the past winter I did a bar swap and got the usual check engine lights. I cleared them and everything was fine for a short while until they popped back up. I could never clear them again, but I wasn't to concerned as it was in "low performance mode" and wasn't effecting the bike. I'm sure it was a broken or pinched wire in the TBW and was going to address it this winter. Now for the last few hundred miles the engine light is off and no error codes. What could cause this? Should I still pull the bars and address the issue? Really don't want to pull the bars off but I also want to make sure the problem is fixed. Opinions?
Old Sep 4, 2019 | 06:42 AM
btsom's Avatar
btsom
Opinion: If you know how to clear the codes, you also know how to display them. Whether the light is on or not, you probably have a few stored. Write them down, look them up and decide yourself how serious they are or ask for advice once you have some actual information to offer.
Old Sep 4, 2019 | 06:51 AM
nutsandbolts5212's Avatar
nutsandbolts5212
Agree!
Ride Safe!!
Old Sep 4, 2019 | 11:47 AM
grbrown's Avatar
grbrown
Exclamation
Electrical problems can often bite back and leave you stranded. Should you address the issue? You shouldn't need to ask and should have done that when you first found you had a problem!
Old Sep 4, 2019 | 09:44 PM
langwilliams's Avatar
langwilliams
I went through this after a bar swap. That little green connector inside the handlebar for the grip twist sensor is most likely the problem. I cut it out an direct wired it for a while then after a while I guess one broke so I ordered a new sensor an the wire it plugs into.
a quick easy thing to try first is the plug connector on the back side of the throttle body. Disconnect it an clean both sides with electronic parts cleaner an put some electric grease on it an clear the codes an give it a try.
I got the twist sensor an the wire it plugs into on line for around $130, which was less than the local dealership wanted just for the sensor.
RET_SCPO
General Topics/Tech Tips
Nov 28, 2021 05:24 PM
Biker90
Feb 28, 2016 07:02 PM
Kyle C Kirk
Nov 9, 2015 02:13 PM
rjc1159
Jun 6, 2009 10:48 PM
gatorwalt
Jul 24, 2008 10:26 AM
