rear shocks
Old Sep 11, 2019 | 07:03 PM
moonhd's Avatar
moonhd
3rd Gear
Default rear shocks
will a set of rear shocks off a 2015 road glide fit on a 2002 road king?
Old Sep 12, 2019 | 07:56 AM
grbrown's Avatar
grbrown
There isn't a clear answer to that question! Which shocks does the 2015 bike have? If they are air shocks, then yes they will fit and work, just bear in mind that they probably use higher air pressures than your old ones. You may have to sweet talk an owner of a later bike to confirm the pressures to use (the spec of air shocks changed over the years).
If the two shocks have springs and are visibly different when compared, then they will fit, but I personally wouldn't advise using them. The reason is they have different spring rates each side with one performing the compression damping, while the other provides extension damping. To do that as designed they really need the much stronger swingarm installed on the later bikes, to give their best and your s/a isn't anything like as stiff.
Old Sep 12, 2019 | 10:17 AM
moonhd's Avatar
moonhd
3rd Gear
Thanks for your opinion, I’m going to take your advice and not switch the ones on the 15 to the 02.
Old Sep 12, 2019 | 10:20 AM
moonhd's Avatar
moonhd
3rd Gear
Default Rear shocks
Thanks , I’m going to take your advice and leave it the way it is. Buy new for the 02
Old Sep 12, 2019 | 10:38 AM
Kermie's Avatar
Kermie
Moon that is a good choice, as the 2015 and 2016 shocks on the customs are no good. They are low which makes the bike look cool with a low stance, but are terrible on the road.
Old Sep 12, 2019 | 11:57 AM
moonhd's Avatar
moonhd
3rd Gear
Thanks, original what I had planned is to put new revo-a’s on the 15 road glide and take the original ones and put them on the 02 road king.
Old Sep 12, 2019 | 01:05 PM
Dynamick's Avatar
Dynamick
Good call on the Revo-A's, but yeah just sell the '15 shocks for whatever you can get and put the money toward some Progressive's for the Road King; even those would be a big improvement.
Old Sep 12, 2019 | 02:00 PM
moonhd's Avatar
moonhd
3rd Gear
Default Rear shocks
Thanks everyone for your help and suggestions.
Old Sep 12, 2019 | 06:26 PM
Kermie's Avatar
Kermie
I put Revo-A's on my 2015 and did the forks with AXEO and it is night and day.. You will like the Legend suspension.
Old Sep 12, 2019 | 07:06 PM
moonhd's Avatar
moonhd
3rd Gear
Thanks Kermie! That’s I’m going to do, rears first and front end second.
