Fall oil changes
Old Oct 9, 2019 | 09:51 AM
Take's Avatar
Take
Hey guys,,,,this is my first Harley so please don't laugh too hard,,,,I just inherited a 07 Roadking and it's time the change fluids,,,,I guess ya'll call it a 3 hole change, 1,Motor and filter,2 transmission, and 3 Primary...I understand everyone has their own special blends of fluids for each hold,,, but isn't there something I can use that makes this easier? Like maybe 1 type oil for all 3 holes? Nenquiring minds need to know,,what Shoukd I use?
Old Oct 9, 2019 | 10:00 AM
NorthWestern's Avatar
NorthWestern
Yes, you can use the same 20w50 in all 3, run down to your dealer and just pick up one of their oil change kits.
Old Oct 9, 2019 | 10:19 AM
Take's Avatar
Take
Thanks North Western for the heads up,,,,zmy next questions would be synthetic ,blend or regular oils?
Old Oct 9, 2019 | 10:27 AM
NorthWestern
Ha! That is one of the biggest debates on this, or any other site that involves an engine!
There is a significant cost increase for synthetics, of course. You can get by with either, they have a kit with the HD 360 dino oils. Run down there, and see if you want to pay the extra price. I myself like synthetics.
Old Oct 9, 2019 | 01:40 PM
Zerk's Avatar
Zerk
Originally Posted by assiniboine
Any engine operating in dusty conditions (country gravel roads) will benefit from an oil/filter change.
I don't think the question was, should you change your oil or not.
Old Oct 9, 2019 | 01:42 PM
Zerk's Avatar
Zerk
For an 07 you need a filter, oil, and 3 orings, if you choose to change. I keep some on hand, but don't changed the, every time. Not sure if a kit is needed, or wonder if it costs more.
Old Oct 9, 2019 | 02:39 PM
dyna07custom's Avatar
dyna07custom
I always store with clean oil filter
Old Oct 9, 2019 | 04:37 PM
assiniboine's Avatar
assiniboine
Noted!
However, there is a lot of controversy over the frequency of an oil change? An engine is basically an air pump, huge volume CFM go thru it. A dusty atmosphere contaminates oil very quickly.
Personally I drain the hot oil pan every fall and change the filter - the other 2 holes as per spec.
One thing to be mindful of if ur running ur bike in the fall - at the end of the day top up the tank to prevent condensation and by extension rust forming in the tank. Really fks things up!
Old Oct 9, 2019 | 06:03 PM
Zerk's Avatar
Zerk
I don't think anything wrong with changing it. I just changed the oil last week one of my bikes. I am not changing it again before I store it.
How do you measure damage? I got 80 and 60k miles, will I get 120 rather than 150? I dunno.
Old Oct 9, 2019 | 08:31 PM
NorthWestern
I am well aware of what is needed for an oil change, I was simply trying to help out the OP. HD has those kits in a box.
As for the items you mention; I buy the o-rings in bulk, and am working through a case of Wix filters I bought 3 years ago.
