Heat issue
As many have stated, the rear cylinder is always hotter than the front. I've never actually measured the differences... so I have no experience to draw from on what is, or is not, a normal difference.
Your delta between front & rear seems excessive for 1 minute of running, on the kick stand.... but that is just my gut feeling...
It has been awhile since I have owned and worked on an EVO, and I never worked on the MM FI system....
The popping may be related to the heat issue or maybe not... decel popping can be tune, exhaust leak, intake leak, etc... a hot running cylinder can be tune, intake leak, bad injector, etc...
Since it runs good, it may not be the tune or a dirty injector...
You can do some checks yourself for cracked/loose/leaking exhaust, or intake.
If you don't feel comfortable checking yourself, or can't find anything wrong, I suggest you try to find an independent shop that knows the MM FI, or at least has EVO experience, and have them take a look...
It may well be normal, but I don't remember thinking my '89 Heritage (EVO Engine) was a hot running engine at anytime during the years/miles I owned it....
Now, you've done all the above. Before you start your motor, pull the plugs and have a look. Probably both ashen gray from running too hot (lean). Replace them. I like Autolite 4265s. Run whatever flavor blows your skirt up but for the love of God, don't run Champions or those crazy weird two prong things. Big twins like to run on the fat side (rich). Your bike will run better, you will lose that amount of hesitation you feel when trying to accelerate a little hard, and it will run cooler. Oh yeah, no more popping either. I did all this on my 98 RKC, made a huge difference.
Carl
