Right cam choice
Old Nov 4, 2019 | 10:03 AM
AlexBelarus's Avatar
AlexBelarus
Thanks !
I’m just thinking if it possible to get more tq the with 222 woods
Old Nov 4, 2019 | 10:20 AM
Fireball Jack's Avatar
Fireball Jack
Well I think I would find a new engine guy. Just with 222's it made 15HP and 15 LBS of torque, The Cycle-Rama 570-2 makes a little better,
Old Nov 4, 2019 | 12:41 PM
AlexBelarus
So I think I will try cyclo Rama . How do you think do I need just cams. Pistons and higher comp will be good with them ?
Old Nov 4, 2019 | 01:13 PM
eighteight's Avatar
eighteight
Post number 10 show numbers very close to your desired results.
Details what products are used
Stock pistons and compression the way I read it.
Old Nov 4, 2019 | 04:43 PM
eighteight's Avatar
eighteight
Default Upgrades in Eastern Europe
As Steve explained your cam choice is dependent on compression
you might consider a bolt in cam with comparable specs to the choice used on the graph.
should this prove to be less improvement than desired you could then later change pistons and add compression
even if you had to change cams a second time you would duplicating a minimum of parts cost and saving a ton of labor. ( no top end removal in first iteration )
what is the availability of euro 98 octane fuel in your riding area? 95?
thats 93 and 91 on this side of the pond
good luck
Old Nov 4, 2019 | 04:55 PM
Bafflingbs's Avatar
Bafflingbs
Go here, https://www.hdforums.com/forum/engin...1-and-2-a.html, and read it, until you understand it. Then make your decision. Or, call one of our sponsors, and have them work up a package for you. Resist over camming your bike! That is the biggest mistake most people do. Also, your choice of exhaust, can make or brake all you’ve done.
Old Nov 4, 2019 | 05:01 PM
lefty33's Avatar
lefty33
Originally Posted by AlexBelarus
Hello buddies
I’ve got serious question
now I have 103 ho with power duals and oversized titans , cvo ac, fp3
now wanna put some cams . I think also will use some forged pistons and better oil pump
so I cannot decide between : woods 222,999, cr570, Andrew 57,tts 100
i ride between 2000-3500 all the time .
guce me some advice please
Or...if you're not in a hurry, keep an eye on this post before deciding. Fuel Moto is doing quite an exhaustive test on most of the popular cams in a stock 103 to give a realty good baseline.
https://www.hdforums.com/forum/touri...m-testing.html
Old Nov 4, 2019 | 05:58 PM
Sam2010's Avatar
Sam2010
Originally Posted by Fireball Jack
You should contact Fuel Moto they get you going with a good plan. If you want the most out of the build a good dyno rune is the only way to get there. Lose the FP3!
Yes follow Fuel Moto they are right now in the middle of testing a whole bunch of cams and they're going to be posting data in the next few days on straight bolt in cams.
Old Nov 4, 2019 | 08:02 PM
Bafflingbs's Avatar
Bafflingbs
My money’s on the Cyclerama 570-2’s.
Old Nov 4, 2019 | 08:11 PM
langwilliams's Avatar
langwilliams
I have the cycle Rama 570's....by bike had 41K on it when I installed them so I pulled the heads an had a valve job an seals done. I put the .030 head gasket on when I put it back together to get a little bump. I got a tuner from Fuel Moto an they sent me a base tune to start with that works pretty well. Gonna get a real dyno tune before next riding season. Hillside is also on here an they build some nice motors an combo's too. Also twist the wrist some...that bike bike roar.
