What was that
Old Nov 4, 2019 | 05:55 PM
tinsnips's Avatar
tinsnips
Default What was that
So bike was hard to start last couple of days then yesterday got it started , Gave it a little throttle then BANG.and a Backfie WTH?
rolled it back into the garage and tried again this morning and started right up. Any ithoughts
Old Nov 4, 2019 | 05:58 PM
Serge A. Storms's Avatar
Serge A. Storms
Weird fluke, if it doesnt do it again dont sweat it.
Old Nov 4, 2019 | 06:07 PM
tinsnips's Avatar
tinsnips
That’s what I was kinda thinking It actually started right up today but didn’t take it out
Old Nov 4, 2019 | 06:13 PM
btsom's Avatar
btsom
What was the ambient temperature for each start? Mine is not happy taking a throttle flick when cold, especially if I haven't ridden it in a week or longer. Was the cold idle rpm up where it should have been or was it running a little slow the time you had the backfire? How many miles, might it be due a fuel filter change? How much gas in the tank, is the level low enough to encourage over night condensation on the inside?
Old Nov 4, 2019 | 07:24 PM
tinsnips's Avatar
tinsnips
Those are all good questions and good points Bike was cold but was just ridden the day before. Full tank but didn’t think about the fuel filter Thanks for the input
Old Nov 4, 2019 | 09:20 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Gremlins!
Old Nov 4, 2019 | 10:31 PM
TheMurf's Avatar
TheMurf
Default What was that..
Possible intake gasket leaking.. Gas seeps past the gasket, acclimates in the combustion chamber, you hit the starter and the spark ignite's it, causing the explosion and backfire.. I would have it checked, do a cylinder leak down test..just for piece of mind.
Had a car blow the intake manifold right off he engine years ago, due to a bad gasket..
Old Nov 5, 2019 | 08:49 AM
NorthWestern's Avatar
NorthWestern
Originally Posted by OldEnuf2NoBtr
Gremlins!
No ****!
What bike?
What engine? (like, does it have EFI?)
What ambient?
When was the last time you rode it?
Battery low?
Backfire out the pipe, fireball?
Or did it backfire through the intake?
Sooo many possibilities, and with no info at all from you we can only guess.
My guess is; it's an EFI bike, and had marginal power left in the battery, and with colder weather you got some gas fumes in the exhaust pipe when she sparked off for a sec.
Make sure air filter, etc are all good, charge the battery fully, and ride on. I would not let a little backfire worry you, unless something more significant happens.
Old Nov 6, 2019 | 11:51 AM
tinsnips's Avatar
tinsnips
Goin off to the mechanic hopefully next week. But in the mean time it has started right up a couple of times with no issues.
Old Nov 6, 2019 | 11:57 AM
svarnster's Avatar
svarnster
[QUOTE=NorthWestern;18654930]No ****!
What bike?
What ambient?
Battery low?
Make sure air filter, etc are all good, charge the battery fully, and ride on. I would not let a little backfire worry you, unless something more significant happens.[/Q
