gear cams vs silent chain question
Old Nov 12, 2019 | 05:10 AM
Gas Smasher's Avatar
Gas Smasher
I agree with the comments that proper set up shouldn't have any appreciable noise. I installed gear drive cams in both of my Softails and there is a very slight whirring noise if I listen for it. Nothing noticeable.
Old Nov 19, 2019 | 09:40 PM
Policeking!'s Avatar
Policeking!
I went to gear drive on my 2004 Roadking when I bought it in 2009, not enough noise change to worry about. The peace of mind not having to ever worry about tensioner wear and the catastophic problems that failure could bring is PRICELESS.
Old Dec 17, 2019 | 09:19 AM
1of2's Avatar
1of2
"Moderator"
I can't hear it on my bike. I didn't even know they were in there until I looked too see how bad the tentioners were worn.
Old Dec 24, 2019 | 06:18 AM
sB43's Avatar
sB43
I just switched to gear drive on my 2000 Ultra. That was the first thing my guy told me he had to check (the run out). I really don't hear any noise. I did the S&S 509G ( the complete camchest overhaul).
Old Dec 24, 2019 | 06:20 AM
Bass Player's Avatar
Bass Player
No noise on my Springer.
Old Dec 24, 2019 | 08:41 AM
eighteight's Avatar
eighteight
Another vote for gear drive.
Old Dec 24, 2019 | 09:20 AM
Zedbra's Avatar
Zedbra
A little more eye candy, just installed a few weeks back. I don't notice any odd noise from the gears.
Attachment 617108
Old Dec 24, 2019 | 10:02 AM
hattitude's Avatar
hattitude
There's two issues with the gear drive cams....
First is the runout. If you have over .003" crank runout, there is no way to install the gear drives and not have accelerated wear and/or damage. Gear drive cams should not be used if your crank run out is more than .003" (some say you can use them up to .004", but S&S says .003")
Second is that if your runout is less than .003' and you are a candidate for the gear drive cams, you should be sure to measure the gear backlash during the install. If you don't measure the gear backlash and confirm it's within accepted parameters, it will at least cause noise from the gears and can cause engine failure.
S&S has this caution in their install instructions concerning adjusting the gear backlash:
"Too much backlash can cause excessive gear noise or clicking caused by the reversing of the forces applied by the lifters to the cam lobes. Insufficient backlash, will cause gears to whine, wear prematurely, create excess heat, and may cause breaking of the gear teeth and engine failure."
Old Dec 24, 2019 | 11:12 AM
sB43's Avatar
sB43
And that my friend is exactly what my guy told me. I guess my Ultra was compliant.
He's probably the best Harley Mechanic in our area. Jason. at One Forty One Speed Cycles, Winchester VA. I'm very happy with my new cam chest work.
https://www.facebook.com/1Forty1SpeedCycles/
Old Dec 24, 2019 | 11:21 AM
smitty901's Avatar
smitty901
Gear cams are a target use engine mod. Race performance. Very unforgiving on a road bike. The slight gains are meaningless. Now let the claims of magical results flow.
