Front Suspension this Year
Old Dec 3, 2019 | 08:51 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The servicing of the front forks is basically gone with Prog. monotubes installed.
Old Dec 4, 2019 | 04:55 AM
grbrown's Avatar
grbrown
Cool
That's not entirely true! Your forks still slide up and down and need lubrication, so will require oil changes at the usual intervals, plus seals and bushings at intervals. You do avoid getting involved in 'which oil is best' for ride quality, as that is now down to your cartridges!
Old Dec 4, 2019 | 07:00 PM
seniorsuperglideE8
The monotubes installed in my Road Glide are a gas charged shock at the top end with a progressive wound spring and is attached to the lower leg in the traditional method. there is 5 ozs./147.865 Milliliters of oil, primarily for corrosion control within the fork. there is no traditional oil bath shock system in the fork leg that HD has had for along time.. A very simple design.
Old Dec 5, 2019 | 04:11 PM
23Seven's Avatar
23Seven
Can’t wait to get it dialed in... It will be nice to have the bike set up as it should have been from the factory.
Old Dec 5, 2019 | 04:24 PM
Indawynd's Avatar
Indawynd
Forks need work on mine this winter. I am leaning axeo after reading so many reviews on the progressives not being the be all end all solution. Lots of good stuff on them but enough no so good reviews to make me think twice.
Been meaning to ask. After the summer with your RT pipe do you love it as much as I do mine?
Parts Giant
Parts Giant
Apr 23, 2018 02:50 PM
BigB1833
Jun 19, 2015 11:07 PM
phaedrusarcher
19
Mar 1, 2013 02:17 PM
rleeryder
Mar 18, 2008 12:13 PM
seikan1
Sep 8, 2006 02:24 AM
