Throttle body intake question
Old Dec 15, 2019 | 10:48 PM
Jeffi204's Avatar
Jeffi204
Stage I
Default Throttle body intake question
I have 05 classic with big bore kit cbc http heads stroked to 103 with stock 88 injectors and throttle body also big cams and pro pipe want to go to bigger injectors and throttle body .what to stick with harley parts any suggestions
Old Dec 16, 2019 | 10:50 AM
hattitude's Avatar
hattitude
Who is going to tune it...?
If you have a good, experienced tuner, I would consult with them about throttle body and injector size...
You need to feed the engine the proper amount of fuel, but bigger isn't always better....
Tell your tuner what mods you are running, what your performance goals are, and then listen to their recommendations....
Old Dec 16, 2019 | 03:09 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
I thought the 25 degree injectors ( which I think were in that year) flowed pretty good, the tuner is going to set the injector pulse to give it the fuel it needs.
as to the 58MM throttle body..... you'd need a set of heads that really flowed to need that much capacity....
It is really up to the person who built the engine to tune it.... there are sooooo many variables in a Harley motor, especially where head work has been done... it is the ultimate quadratic equation ( or big jigsaw puzzle) trying to match cams with pistons, with heads, and exhaust ... plus a tuner to get all the components to play nice together... something that works in a TC88 runs like crap in a slightly larger engine...
Old Dec 18, 2019 | 04:23 AM
Magnut1's Avatar
Magnut1
I am considering a stage 4 for my 14 103. I talked to Fuel Moto and Zippers and they both say the stock intake and injectors are good for up to 120 hp or so. Any higher you would need to go with the big intake and higher flow injectors.
kitchen
Nov 20, 2019 02:45 PM
MisteredEd
Sep 26, 2019 12:20 PM
Nostradamus74
Feb 24, 2016 02:29 PM
Wmitz
Engine Mechanical Topics
Jun 4, 2014 08:11 AM
Jerry Pbury
Apr 24, 2013 05:06 PM
